JMB RetrofitsChris Nott
    Oct 2008
    188
    Clutch and flywheel options S3/A3 quattro
    help needed wot options are there for new clutch and flywheels my flywheel rattles really bad when i switch the car off clutch is slipping slightly and bites very near the top its also made the gearbox feel abit sloppy the car is a3 quattro turbo sport k04 conversion runnin amd custom map 270 bhp should i do standard replacement or dose anyone know any resonably priced uprated ones im not to sure about those dodgy ebay ones i can do the work myself so just any prices for standard replacements or uprated items thanks
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Personally I'd go for option 2 on this link:
    http://www.r-techpower.co.uk/r-tech-producs.php
    550 OEM Solid fly wheel conversion. Inc 2.0 16v Solid fly wheel, G60 friction & pressure plates & bearing - including fitting. Give them a call for prices for just the items.
    Homer Simpson
    Oct 2008
    188
    dont think they will fit the quattro gearbox mate think these options are for fwd cars only me thinks
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by djdougalno1 View Post
    D'oh, I should of read the title a bit better (too much alcohol....).
    I'd go with OEM then to be fair.
    Homer Simpson
    Oct 2008
    188
    looks that way but hopefully someone might have done something diffrent thanks anyway
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    I fitted the spec steel single mass flywheel and one of their full face kevlar clutches, was brilliant. Got them both from 034 motorsport:
    Flywheel: http://www.034motorsport.com/product...ducts_id=16541
    Clutch: http://www.034motorsport.com/product...ducts_id=16535
    The only word of caution I would say was that I found that sometimes the clutch would stick, however that might have been down to the fitting more than anything else. There was more vibration however overall I'd do it again purely to loose the dual mass slop and the fact the flywheel itself is unlikely to fail again.
