AH FabricationsEM Tuning
Results 1 to 9 of 9
    Oct 2009
    86
    K03 quattro downpipe and manifold
    after looking everywere for a downpipe for a a3 qauttro am going to get a custom 3" job, was wondering if i buy a s3 milltek catback will it fit if i get the downpipe to meet, i know it will not marry up with the k03 downpipe, but if i make the downpipe to join up, surely this will work
    13.8 santapod gti fest 2010 class g 1st place winner. A3 1.8 20vt 180 quattro, Revo stage 2.5 map,[/B] Forge tip, forge cold side, Forge splitter valve, Carbonio cold intake with aem filter,decat pipe, 2.5inch exhaust, k03s turbo with forge actuator, revs fmc with forge houses, j n75 valve, 4 bar fuel reg, hid's, 17" tt alloys t1r
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,067
    hmmmmmmmmmmmm
    interesting idea.....
    Why will a normal ko3 downpipe not fit? are the downpipes different on FWD and 4wd cars due to the transfer box? I always thought you could fit a standard downpipe/decat onto both the TQ and the FWD models.
    Oct 2009
    86
    not sure was toying with the idea to buy a cheap 100 pound downpipe of bay just to see if it would fit
    www.badger5.co.uk
    May 2004
    nr Glos
    6,941
    twin cats on 4wd one, as they had to use 2 x smaller pipes to clear the transferbox i think.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,067
    aaaaaaaaaah, I knew the S3 had twin cats, didn't realise the 4wd A3 had twin cats as well.... makes sense really!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Very tight in the tunnel with the prop shaft etc in the way. Twin cats are there to allow for more ground clearance as the prop sorta sits in the middle of them...
    <tuffty/>
    www.badger5.co.uk
    May 2004
    nr Glos
    6,941
    the 150/180 model are smaller pipes than the s3 one, as well as being different shaped of course (k03s vs k04 respectively)
    bill@badger5.co.uk
    Oct 2009
    86
    ok thanks for replys, so if i got the s3 catback milltek and got a custom downpipe will these work thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    S3 exhaust is not a straight fit on an A3. S3 exhaust is designed to exit the rear of the car where the A3 tailpipes drop down before the rear valence.
    You will need to cut a section out of the rear panel and a section out of the bumper (unless you have an S3 rear bumper of course). The hangers will be different too but S3 ones can be bought to fit.
    Byzan A4 (Mark) fitted an S3 exhaust to Stacies A3 TQS so might be worth asking him for pointers.
    <tuffty/>
