EM TuningChris Nott
Results 1 to 7 of 7
    mike-turbo's Avatar
    Sep 2009
    82
    New clutch help S3
    right lads ive fitted a new clutch to my audi s3 03 reg 8l i have fitted a new dual mass flywheel, clutch ,master cylinder, feed pipe to slave cylinder and a new slave cylinder the problem i have got is it very hard to get any gears i can get all gears when the engine is off but when i start it its very stiff and can't get reverse.when it goes in gear the clutch pedal bite seems fine do you think its air in the pipe still?as no more air bubbles come out when i bleed it.
    S3 Paul's Avatar
    Oct 2006
    2,764
    mine was slightly wierd when first fitted... But over the first week, the pedal "came back" and now all it fine,
    When bleeding it did you just let the bubbles surface or push the pedal down with your hand so as to not cover the engine bay and the poor chap checking for bubles in fluid?
    Noggy Blue 2001 S3
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    I found the clutch on the 8L bled better by gravity than by pressure, no sure why!!
    I just pumped it a few times, released the nipple and let the fluid run clear, nipped it up, job done !
    mike-turbo's Avatar
    Sep 2009
    82
    i've tried both methods pressure and pumping manual.i hope its a air lock and not the clutch.but now when i bleed it its all clear no air bubbles and still very hard to engage gears.
    Apr 2004
    12,520
    In my experience, if it feels and looks right ,it is.
    Any chance the cables need some adjustment/lubrication
    mike-turbo's Avatar
    Sep 2009
    82
    Quote Originally Posted by Byzan A4 View Post
    not sure but all the gears select easy when then engine is off only when engine is started im having problems.
    Aug 2009
    169
    Did you put the clutch plate in the right way round? If ur sure that's ok then it's air, you need to open the nipple then down on the pedal, lock off nipple and pull pedal back, repeat this process a few times then pump up the pedal to see if it feels any good.
    S3, 4 wheels, magical B8's, Eibach, Pipewerx equipped, glass windows, metal engine, silver paint.
