    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Help with warning light
    Hi,
    Since its started to get cold, every morning I start the car up in my garage the light flashes up on the dash... it's then gone after about 90 seconds of the car idling. is this a problem or just the fact the coolant would be quite cold on first start up due to the weather.
    Cars running spot on no problems I can notice, just this dam light keeps bugging me in the morning.
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
    Essflee's Avatar
    Mar 2008
    2,007
    There is another thread on here recently been started for the same problem.
    When I used to get this with my A3 'only on cold mornings' it turned out to be the metal prong that measures the coolant inside the bottle, it gets coroded over time, simply remove and clean up with wet and dry/ soft sand paper and it should cure the problem...
    revo'd
