EM TuningAH Fabrications
    Sep 2009
    21
    Coolant sensor level/temp warning.
    Please help - done a search - since yesterday morning been getting coolant level /temp warning on dash when first starting in the morning. Checked the levels looks ok - well above the max mark but I figure this is because it has expanded whilst heated. Same thing thing morning - goes away after a few minutes and is fine rest of the day even after a cool down.
    From searching is this the sensors being corroded/having muck stuck on them. How easy is it to get to the sensors? Just through the top of the coolant filler container? Any tips /advise would be much appreciated.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    My car does that too on cold mornings. I know the coolants fine but I always get the loud beep and the warning sign flash up when I start it in the mornings. It goes away after a few seconds.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Essflee's Avatar
    Mar 2008
    2,007
    My A3 used to do this on cold morning exactly as you describe. It's the metal prong that sits in the coolant, from memory I think you simply unscrew it from the header tank and just clean it up with some wet and dry or the like, should be alright then though the problem may return next year.
    Still at least it's nothing serious...
    revo'd
    LordNelson's Avatar
    Aug 2009
    167
    have you run VAGCOM on this to get a fault code? i have exactly the same thing and have had it through the summer also.
    my fault code is..01271 Positioning motor for Temp flap (V68) blocked or no voltage - Intermittant.
    im guessing this has something to do with mine, as well as a faulty thermostat.
    the warning goes off after a min or so. however i do need to get this fixed. anyboday any ideas how to do this.....and where it actually might be?
    2000 Audi S3
    1967 VW Beetle
    Where Do I go From Here?
