EM TuningAH Fabrications
Results 1 to 9 of 9
    Crazypete00's Avatar
    Oct 2007
    225
    Temp Sensor or Thermostat
    Hi, another one of these questions.
    Ive heard somewhere that if you get the Coolent temp to display on the Climate control and compare it to the Needle temp gauge you can assess what part you need.....
    So i did this. climate control was at about 60c the needle was at 75-80c
    does this mean the sensor is knackered? the thermostat seemed to open up at around 30c because after 30c the temp shot up to 50 pretty quickly.
    if it is the sensor which one on eurocar parts do i need. i have a AMK facelift S3
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    If your dash needle doesn't reach the halfway point (90 degrees) and stay there then your thermostat will need replacing. The thermostat is completely mechanical and opens when the coolant temp gets up. I'd start by replacing that first if it doesn't stay at 90 then see how you get on.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jun 2003
    World of my own
    9,813
    You'd really be better replacing the temp sender first as it is an easy 10min DIY job.
    If the thermosat is stuck open then the car will only reach operating temp when idling for a long time.
    If the thermostat is stuck shut then the car will overheat on the motorway.
    If the temp sender is faulty then you will get quite random results. Car never reaching 90, stalling when cold, hard to start, idling like a dog etc etc.
    Alex Turner
    Oct 2007
    225
    its a strange one, car doesnt overheat so i dont think its stuck closed. if anything it struggles to get to 90c, but when it does it doesnt stay there for long and drops down to 70c. however i dont have any problems starting it, and it idles perfectly even at the moment with the -7c weather.
    so i think its pointing to the temp sender, inconsistent results.
    Also its an easier job to replace and the part is roughly the same price.
    is this the right part? temp transmitter?
    http://www.eurocarparts.com/ecp/c/Au...6dbbb26c2&TMPS
    or theres this one
    http://www.eurocarparts.com/ecp/c/Au...02f19673f&TMPS
    or this one
    http://www.eurocarparts.com/ecp/c/Au...8c7e71d68&OTSE
    theres so many, temp sensors of some sort
    Jun 2003
    World of my own
    9,813
    Just get from a dealer they're only 20
    Alex Turner
    Oct 2007
    225
    ye but which one is it?
    Oct 2007
    225
    or where is the sensor located so i can take it out and find a part number
    Jun 2003
    World of my own
    9,813
    That's the point, give the dealer your reg and they'll give you the right part number.
    Alex Turner
    pauldazzle's Avatar
    Cardiff
    549
    Sounds like your thermostat is stuck open. Still worth changing the temp sensor though as it's really easy. http://www.thetradepartsspecialists.co.uk genuine parts & a bit cheaper than main dealers.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
