Volks AutosSky Insurance
Results 1 to 9 of 9
    Dec 2009
    9
    Is my clutch slipping?? S3
    hey all, was wondering if my clutch is slipping or if it could be something else! Tends to happen starting from 2ng gear on up, hit about 3rpm then revs jump around for little while before power kicks in! any ideas??
    Dec 2009
    Chatteris cambs
    Hi
    My works van has just had a clutch fitted and the problems that i had was when you put your foot down the revs would go up and then drop of. You did not have to move your foot for this to happen found to be fuel (derv)leaking in to the bell houseing from the return line. One way to tell if you clutch is sliping is to put the park break on then try to pull away do this in top gear if it rev up then pos clutch but should stall engine. Ricky
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    does it also do it in 3rd 4th 5th 6th ??? mine shows up in 6th and 5th atm when I boot it from 3000 rpm on the motorway. If its doing 3500 then it does not slip
    red to red black to black blue to bits
    Dec 2009
    9
    yeah, slips in all those gears, any revs over 3000rpm! Weird thing is it was running ok for 2 weeks when i put redex in with a full tank of ultimum, then after re filling with just the ultimum it has started doing this again!
    Dec 2009
    Chatteris cambs
    my van did, this was due to build up of derv then would slip like mad then would be ok for a month. Not saying you have a leak but just have a look can you see in the bell housing for any contamination.
    Dec 2009
    9
    am abit of a blank canvas lol, where would i find the bell housing and what sort of leak could it be?
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    yer sounds like the clutch mate, dont suppose you have got it remapped have you?
    -AUDI A3 1.8T-
    coldside dumpvalve relocation kit/powerflow exhaust/k+n shielded air intake/ JOM coilovers/forge splitr/forge carbon fibre engine cover/soild flywheel conversion/REVO
    Jun 2009
    162
    Quote Originally Posted by j444rdy View Post
    Thats not weird dude, a clutch wears out like all consumables. Im sure it has been running ok for that past 10years, then it wore out and now needs replacing.
    The petrol or "injector cleaner" you put in would make no difference to your clutch slipping.
    As a previous post said, put your handbrake on really tight, and bring the clutch up in 1st, giving it some beans, you should be able to hold a constant revs ~3k without the clutch slipping.
    He was talking about oil leaking onto the clutch, which could cause the clutch to slip. Look around where the gearbox meets the block to see any naughty leaks.
    Dec 2009
    9
    Thanks for that, will check when this snow clears up
