Sky InsuranceBadger5
    Feb 2003
    107
    Exclamation Changing ignition barrel
    Hi Guys,
    I needed some advice about changing my ignition barrel on my A3. As the reader coil failed, so I sourced a brand new ignition barrel made for my current keys from Audi.
    I read some post on google and have been adviced that I have to remove my steering wheel. Is this true?
    Also I dont have to reprogram my keys as I am still going to use my old keys.
    Do any of you guys have a step by step guide on how to change the barrel on my A3 P reg?
    Feb 2003
    107
    Thumbs up How to.
    This morning I started to look around from some workshop manuals and I found one. This help me to remove the barrel from the steering column. I didnt listen to the bit about removing the steering wheel, as I fiddled around and got the top and bottom plastic covers off. This saved me alot of time.
    This is how to remove the barrel once the covers are removed I could not post the pictures, can anyone tell me how to do that:
    1. Spare key is required for removal of lock cylinder as the following operations can only be performed with an ignition key with a flat grip, i.e. no light and no remote control.
    2. Turn spare key to "ignition ON" position, thus aligning recess in trim -arrow- with hole in ignition lock.
    Note:
    3. Insert steel wire or pin ( approx. 1.5 mm) in hole -1- as far as it will go, at the same time pulling lock cylinder -2- with reader coil out of steering lock housing -3-.
    Note:
    If lock cylinder has to be replaced, always heed specifications for immobilizer reader coil replacement.
    Installing
    Install in reverse order, paying attention to the following:
    ‒ Insert spare key in lock cylinder and turn to "ignition on" position.
    - Re-insert steel wire/pin -1- in hole on end face as far as it will go.
    ‒ Insert lock cylinder -2- with reader coil in steering lock housing -3-.
    ‒ Then pull out steel wire and firmly press in lock cylinder until catch is heard to engage.
    ‒ Plug in connector at immobilizer reader coil.
