Chris NottAH Fabrications
Results 1 to 9 of 9
    44
    Rev needle problem
    hi guys and girls
    sometimes when i dip my clutch at a giveways or t-junction anywhere really the revs fluctuate between 500 rpm and 900rpm its like as if the engine wants to cut off and then it levels off and no problem
    this doesnt happen at every junction and i understand its not the end of the world but hey im a perfectionist unfortunately and want the car 100%
    i have recently remapped the 1.8t replaced temp sensor and thermostat and replaced the ignition amplifier
    what the hell could this be now !! aaaaargh
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Unplug the maf, go for a drive and see if it does it, if it doesn't you need a new maf
    44
    cheers mate
    44
    if it is the maf .are these the early symptons or signs of it going worse in the near future .is this how it starts
    pleeeeeease help !!
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Maf can do all kind of things, poor idle, poor fuel comsumption, poor boost etc How is it running generally? It could just be a case of your throttle body needs a clean
    44
    mmmmm gonna try and clean the throttle body first ,will carb cleaner suffice ??
    LordNelson's Avatar
    Aug 2009
    167
    [QUOTE=boostboy;869907]hi guys and girls
    [QUOTE]
    How much were the Temp Sensor and thermostat? and were they easy enough to change?
    2000 Audi S3
    1967 VW Beetle
    Where Do I go From Here?
    44
    its a doddle tenner all in off egay , 5 mins to replace theres a how to in google and maybe on here,
    p.s is your car an s3 my 1.8t is that colour whats the name of this colour ?
    LordNelson's Avatar
    Aug 2009
    167
    Yeah its an S3....MING BLUE. although this will polish up to appear much darker.
    il have a look on fleabay for the parts then....job for xmas i think
    2000 Audi S3
    1967 VW Beetle
