Chris NottJMB Retrofits
Results 1 to 8 of 8
Thread: ABS/Headlights
    Aug 2009
    14
    ABS/Headlights
    When I was larking about in the snow on the way home, I noticed that when the ABS kicks in the headlights would dim slightly. Is this normal behaviour?
    Can anyone shed some light (cough) on what is happening?
    Oh and the car is a 2000 A3 Quattro.
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Do you mean ESP?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Your battery might be on its way out
    Aug 2009
    14
    Nope, I mean ABS. My car doesn't have ESP...
    But do you have an idea if it was the ESP?
    Aug 2009
    14
    I did wonder about the battery..
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Maybe the way it works causes a huge drain in the battery. Much the same (but greater) as when you turn on the heated rear screen or try and put an up window up. Mine dim but only VERY slightly when I do the above.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Aug 2009
    14
    Update..
    Today I noticed that the first turn of the starter was a bit slower than normal.
    So went to halfords and had them check it with their fancy Bosch tester. And yep the battery is knackered. I've been to the local Audi dealers and ordered up a new battery (80), but are the cheaper alternatives any good?
    s3ollie's Avatar
    Jan 2007
    749
    although the halfords battery's are a bit cheaper they are also a bit bigger and a bit of a squeeze to fit in the sleeve/hole in the S3
    8P S3
