Sky InsuranceChris Nott
Results 1 to 12 of 12
Thread: Low head lights
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    Low head lights
    No this isnt the normal motor issue as they are working (i think the lights adjust when switcing on) but they just dont go high enough. I was wondering what controlls the height of the lights?
    Know a while ago i did my Arb's and so had the subframe off and noticed the link that comes down onto the wishbone. Is this the sensor that controls the height if so i will have a play at tring to adjust this and see if it changes the height of the lights.
    Also how can you fix the white adjusters as mine are all brittle and falling off. and im not to keen on spending the silly money Audi want for new headlights.
    Any help would be great as driving home from work is rather scary only being able to see a few feet infront of the car.
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    AjM
    AjM's Avatar
    Living in Blissful Ignorance
    Jan 2007
    Torbay, S.Devon
    295
    Have you got them adjusted as high as they go?
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    i had the same problem, on mine the white manual adjusters on the back of the light broke off. so i used some small circlips to hold them in position. mike
    Nov 2008
    Leicester
    1,246
    They used to be fine infact i used to get flashed as they were a bit high but know its just dame crazy low
    Ive been Badger 5'd
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    i know i was having to put my main beam on because i couldnt see and no one was flashing me.
    Nov 2008
    Leicester
    1,246
    So true! So does anybody know what controls the height of the lights?
    Ive been Badger 5'd
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    theres a sensor on the front left suspension leg and 1 on the rear left suspension arm.
    Deanphoto's Avatar
    fell down the stairs :(
    Sep 2007
    Surrey
    95
    Mine dids this last night although it's now fixed itself.
    My previous TT also did this, I took it into the dealers who manually adjusted them. I'm not sure where the sensor is but I think it's on the offside rear suspension.
    //deanphoto - Automotive photographer
    Sep 2005
    uk
    80
    i have had this problem for ages, what i did was what other people have done and find a wall, park a few feet from it and switch on the light on a level ground and let them rest at a proper level. then disconnect the auto adjusters on the lights. then manually adjust each headlight up till they are both level and u should be ok.
    but dont set them too high or you will be blinding people. as for the broken white adjusters, go easy with them or they will work themselves loose and if u lose them they are a nightmare to find. lucky i got a donor set of headlights from a member on here (thanks once again!) which i used to sort out mine, which make mine good again.
    there is a few posts on here about this so please search them out!
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Proper headlight adjustment requires vagcom doesn't it?
    I lowered mine as the main beam was too high and next to useless. Now its spot on and doesn't dazzle. Dipped beam is a little low though.
    Can't adjust it with shareware vagcom so never mind!
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    Oct 2009
    mine are well too low aswell cant see more than a few ft in front at nighttime
    Nov 2008
    Leicester
    1,246
    Ok know knowing there are 2 sensors i will have a play see if i can solve this.
    Ive been Badger 5'd
