EM TuningSky Insurance
Results 1 to 8 of 8
    Oct 2008
    188
    Passenger window keeps sticking help
    my passanger window keeps stoping when its going up then goes back down again cant get it to close proply unless you help it buy pushing it up with your hand any ideas whats causing it
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    probably exactly the same as my problem! its one of the plastic clips holding the glass in
    -AUDI A3 1.8T-
    coldside dumpvalve relocation kit/powerflow exhaust/k+n shielded air intake/ JOM coilovers/forge splitr/forge carbon fibre engine cover/soild flywheel conversion/REVO
    Oct 2008
    188
    was it an easy fix what should i do take the door card off and check also where are the clips in the runners that hold the glass in
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    i ordered my clips from audi on saturday so should be here by the weekend then im going to give it a go!
    if you take the door card off you should see 2 green clips holding in the glass, if you give the glass a big shake you should see one loose! hang on ill try dig out my old thread....
    -AUDI A3 1.8T-
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    -AUDI A3 1.8T-
    Oct 2008
    188
    thanks guys will take a look at the weekend
    S3KO4's Avatar
    Aug 2009
    London
    850
    Got mine of ebay with as Audi told me they wouldn't sell the clips alone, the new one have metal base covered with pinkish plastic. I would greese the line and other moving rails, just to make it better fllowing.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    audi sold me the clips, he even said he will post them free of charge. they are 2.20 each if your doing one you might as well do the other as these clips are common problems supposedly
    -AUDI A3 1.8T-
