Sky InsuranceJMB Retrofits
Thread: Key needed
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,911
    Thumbs up Key needed
    for this diagram,can you post your suggestion with the number and name please
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    What you wanting jason, for each part to be named? What you broke? haha
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Number 11's the airbox....hope that clears things up for you
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    1 - Fuel Tank Breather
    2 - Charcoal Filter
    3 - One Way Valve
    4 - Turbo.... Duh!!
    5 - Wastgate Actuator
    6 - Diverter Valve
    7 - Brake Servo
    8 - One Way Valve
    9 - N75 Valve
    10 - MAF
    11 - Air Box (well done Tom)
    12 - Oil Breather Thingy (technical name, can't remember what its actually called)
    13 - N249 vacuum reservoir
    14 - SMIC
    15 - Fuel Pressure Regulator
    16 - Throttle Body
    17 - Inlet Manifold
    18 - Cranckcase Breather Valve (thingy)
    19 - One Way Valve
    20 - (as ross said below...) N249
    21 - One Way Valve
    22 - SMIC
    <tuffty/>
    Ross_S4
    Aug 2009
    Dundee
    718
    1 - charcoal filter vent line?
    2 - activated charcoal canister
    3 - check valve
    4 - turbo
    5 - wastegate actuator
    6 - recirc valve
    7 - brake vacuum assist ata guess??
    8 - check valve
    9 - NJ75 (or solenoid changeover valve if you prefer)
    10 - MAF
    11 - engine air filter
    12 - pressure regulating valve
    13 - vacuum reservoir
    14 and 22 - charge air intercoolers
    15-
    16 - throttle body possibly??
    17 - intake mani
    18 - valve housing (for rocker cover ventilation?)
    19 -
    20 - N249 (solenoid changeover valve)
    21 - check valve
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,911
    Thanks Paul,Ross and Tom
    heres your prize pic
