Sky InsuranceJMB Retrofits
    ghost.s3's Avatar
    Apr 2009
    Cape Town
    65
    Weird window rattle that driving me nuts
    Here's an interesting one (tried a search but nothing similar came up). My driver's window has started rattling. Here's the thing though, it just happens when it's fully closed. So it sounds as if it's rattling in the rubber thingies (that's the technical term). As soo as I drop the window, even very slightly, the rattle / creaking disappears.
    Seems like the kind of thing that should be easy to solve - just can't seem to figure out what to start with / do.
    Any ideas? Before I tear the nails from my toes in frustration.
    2001 Mineral Grey AMK
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    I have this but only when closing the door at the minute.
    It has a funny rattle to it when the window is up but if I edge it down even slightly it doesnt do it when closing the door. :s
    Apr 2009
    23
    not sure if this is any help or even the same problem but i had i rattle creak from both my front doors and i found that by cleaning all the rubber seals and the body of the car where the seal rests the noise is gone.this is quite a common prob on post 05 bmw 3 series and it caused by silicone build up from incorrect cleaning products being used or dirt build up.be sure to clean all the seals around the door and car body with silicone remover.hope this helps
    ghost.s3's Avatar
    Apr 2009
    Cape Town
    65
    Quote Originally Posted by Alan W View Post
    Cool, definitely sounds like it's possible. Thanks for the tip dude, will give it a try
    ghost.s3's Avatar
    Apr 2009
    Cape Town
    65
    Tried cleaning it with surgical spirits without any luck. Will get hold of some proper silicone remover and have another go.
