Chris NottVolks Autos
Results 1 to 19 of 19
    A3ster's Avatar
    Oct 2008
    87
    3 days till REVO!!!
    Hi All,
    I spotted a deal on AGU revo maps from a company in Kimbolton so thought I would give them a ring and have a chat.
    Well, I rung the guy up and got no answer, so tried the mobile number. Turns out he is at the track with a customer performing testing (also turns out they do far more than just remaps on road cars) Anyway I ask if he can fit me in this saturday and he says it will be tight but will ring me back
    At this point im not holding much hope, and I said to myself if I cant get this saturday I will spend the money on a new guitar instead.
    Anyway rings back and can fit me but with one hitch, a new rolling road is being put in that day!!! The original offer included before and after readouts, so im thinking OK this is sounding like its not meant to be untill he gives me an offer I couldn't refuse
    200 plus VAT!!!!!!!!!!
    So im in there like swim wear and will write a small review when I get back etc. Sounds like a great deal, obviously would have been better with the rolling road but I cant see any problems occuring from this unless anyone can think of anything? And I assume if you are a REVO distributer then it doesnt matter one you go to they will all be the same"ish"?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    Yes all Revo Dealers supply the same software,good call on the price.
    RR isn't no big deal you'll feel the increase right away,ask about uprgrading the DV to a Forge 007p and also ask advice on coilpacks.
    Revo all the way baby
    A3ster's Avatar
    Oct 2008
    87
    Thanks for the reply voorhees,
    In the respect of the DV mine is only 3 months old(replaced by myself and OEM) will it "break" sooner than later or can It wait till January till I get a 007P?
    On the coil packs, from searching the forum I am aware that the remap may show up any weak points that are already there so have put money aside for 4 new coil packs if needed
    My only other issue is can you explain to me or point me in the direction of a good 1.8T diagram with all the hoses etc. I fell if I increase the power over standard I should know whats going on in there.
    S3KO4's Avatar
    Aug 2009
    London
    850
    I would replace the induction hose, from the air box to the turbo, I know with peak boost under load it will collapse especially in the higher gears.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Pat
    Dec 2006
    512
    Mines going in tomoz be have revo stage 3 put on.. quite interested to see what the outcome will be..
    2002 S3, Project 400, New Build In Progress, I.E 2.0 stoker kit, Big Port AGU Head, Ferrea Valves retainers, springs etc, GT30 compact, Pagparts Manifold, AH Front Mount Version 2, Genesis 550cc Injectors, 044 Fuel pump in I.E Surge Tank, Revo Stage 3 Software, Porsche Brakes, work in progress
    A3ster's Avatar
    Oct 2008
    87
    Quote Originally Posted by S3KO4 View Post
    Is that the TIP, do you have a product number for that?
    A3ster's Avatar
    Oct 2008
    87
    Quote Originally Posted by Pat View Post
    Pat,
    where are you going to?
    Pat
    Dec 2006
    512
    Andy @ LincolnVWspecialist in Lincoln..
    http://www.lincoln-vw.co.uk/
    He will be doing my rebuild next year
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    Quote Originally Posted by A3ster View Post
    Ask the tuners they will put you right about the DV.
    A3ster's Avatar
    Oct 2008
    87
    Thanks voorhees,
    Is there a key to the numbers on the diagram
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    1 - Fuel Tank Breather
    2 - Charcoal Filter
    3 - One Way Valve
    4 - Turbo.... Duh!!
    5 - Wastgate Actuator
    6 - Diverter Valve
    7 - Brake Servo
    8 - One Way Valve
    9 - N75 Valve
    10 - MAF
    11 - Air Box
    12 - pressure regulating valve
    13 - N249 vacuum reservoir
    14 - SMIC
    15 - Fuel Pressure Regulator
    16 - Throttle Body
    17 - Inlet Manifold
    18 - Crankcase Breather Valve
    19 - One Way Valve
    20 - N249 Valve
    21 - One Way Valve
    22 - SMIC
    A3ster's Avatar
    Oct 2008
    87
    Quick update,
    After digging my car out of a blizzard at 6:30am and making a slow and quite frankly un-nerving drive to get the A3 remaped it turns out that my port doesnt work
    It will read but not write. So a little tip for people, check you have coms on an channels before you travel 100 miles in a blizzard to get your car remaped.
    He said he will order a harness and bench flash it so I still get the remap and will have a look at the port at the same time to see if we can get it working for the future. All credit to the dealer he tried his best and coffee and chocolate was flowing, explained a few things along the way such as how dry sumps work etc. They also had a rather tasty clio touring car there and a race spec Elise!
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,382
    sadly mate, the tunner should have warned you this was possible before you went!
    AGU's seem to be very hit and miss with regards to OBD mapping. some can be flashed via the obd port, and some need to be bench flashed. Really early ones need opening up and a new chip soldering in
    Oct 2009
    178
    i have decided to leave mine std without re maps, they are quick enough, and from most posts i see once re mapped people have problems with clutches fault codes etc etc etc i could do without the hastle, im happy as it is
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Quote Originally Posted by ex_scoobydoo View Post
    If you've come from a scooby I'll give you a maximum of 6 months before you consider mapping your S3
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    If you've come from a scooby, i'm quite suprised you think its fast enough in standard form. I mapped mine two weeks after buying it, now its much more like it! I'd still like it faster but at least i can now say 'its fast enough as it is'!
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by ianysm View Post
    Exactly. I came out of a 1.4 corsa (but did come from faster cars previously) and got the S3 remapped after 2 months and its still slow.
    S3 Build Thread
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Its not as fast as my M3 but faster than all the other mapped turbo's i've owned...Perhaps his Subaru was standard which wouldn't be far off a standard S3?
    AUTOMAP
    www.eliteremaps.com
    Oct 2009
    178
    i know what you mean guys, but im happy as it is, my days of throwing cash into cars os over, the s3 is nippy enough i had my fun with the scooby and it bankrupt me at the same time lol, 14000 it owed me on a p reg sti sold for pennies, so im just happy now with some comfort and a little bit of speed when needed, some decent shocks and springs, set of tt wheels and thats enough for me.
    sti was around 300bhp just lightend flywheel polished headers that was it for mods. 2 re builds etc etc blah blah blah lol
