Badger5JMB Retrofits
Results 1 to 10 of 10
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    DIY S3 Front wheel bearing....
    How hard are these to do...
    I've done a few in the past but mainly on Vauxhalls.
    Do the new bearings need pressing into the hub, or does the good old hot water method work? LOL
    Any thoughts appreciated...
    Homer Simpson
    Crazypete00's Avatar
    Oct 2007
    266
    i would say you need a press......
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,576
    I concur.....
    <tuffty/>
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Ok, thats fine. My good old fork and spoon method won't work then!
    Glad I asked before taking the hub assembly apart!
    Homer Simpson
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    You deff need a press.... i managed to do mine at home but it was a real struggle even with some homemade tools and a blowlamp
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Take the hub off and get down to your local garage. Have them press the new bearing in. Should only cost a drink. Will save loads of bashing and swearing.
    Mar 2008
    Oldham, Manchester
    1,110
    It's not so much getting the new bearings in.... if you warm the hub in say the oven and chill the bearings in the freezer then you can tap them in with the outer of the old bearing.... never tap the middle you will ruin your nice new bearings if you do..... the hard part is removing the old outer part of the bearind from the hub.... mine were rock solid stuck and also had to grind the center of the old bearing to remove it from the center part of the wheel hub.... biatch of a job...
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by 666markyboy View Post
    That sounds like a right pain in the chuff. Bugger that, I'm off down the garage with the hub! My mate's garage is a 2 min walk, so he can sort it out and call it my Xmas pressie
    Homer Simpson
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,576
    Quote Originally Posted by HTC View Post
    ...gets my vote... I did this with my A4...
    <tuffty/>
    kitpayne's Avatar
    Sep 2009
    Warminster, Wiltshire
    128
    I went into a tyre place and asked if i could use their press and they were fine. Didn't ask for nothing. let me use their cir clip pliers as well.
