AH FabricationsEM Tuning
Results 1 to 13 of 13
    random101's Avatar
    Sep 2009
    122
    Brake help needed!
    Okay so the car is at a local mechanics where i got the coil overs fitted..
    he is also changing my brakes but couldn't find the brake fluid reservoir
    So could someone please let me know where it is?
    Also
    i have to push out my wheels as they dont clear the callipers (so im getting spacers) but im scared that the center hub rings will not fit onto the hub with the 8mm spacers this could be a problem! also im having problems to source out longer wheel nuts..
    any ideas!! would be excellent
    Also if i push out the front should i push out the back.. i dont care about looks just performance..
    Cheers!
    2000 Audi S3 |Revo Stage 2+ | Revo Select Plus| Custom 3" exhaust |
    |3" down pipe | 120cell High Flow cat | Forge Dump valve |
    |Wagner-tuning FMIC ||Big brake kit 355mm | coilovers |
    ~Wish list~ |Haldex| stage 3+ |
    Kingston's Avatar
    Jun 2009
    Preston
    182
    If he is fitting new brakes he needs to undo the bleed nipple on the master cylinder aswell. The brake fluid pot is under bonnet to the left. Do you have confidence in this person?
    If you widen the track at the front i would widen the track at the back to suit aswell.
    Nogaro Blue 2001 S3 Quattro, Cream leather interior. Miltek Cat back, Induction kit, KO4 Hybrid Turbo, Chipped Remap, Power Boost Valve, Forge RC DV, Compbrake Racing 4 Pot Calipers with 2piece 350x32mm Conversion Front, 2 piece 330x20mm Compbrake Conversion on Back, Discs are Powervane Racing Rotors Gas slotted and internally veined. Hawk Hps Pads, Goodridge Braided lines to Calipers. Bose Symphony sound system. Compbrake Quickshift and side shift. Big thanks to www.Vagperformance.co.uk
    random101's Avatar
    Sep 2009
    122
    Great thanks for that, i have just done a heap of reading and most people seem pretty happy with spacers,
    although one question i am having trouble finding a 8-10mm spacer that is hub centric
    could this because the hub comes out enough so it doesnt need it? if so excellent if not.. where can i find some i have checked out http://www.fk-automotive.de/websale7/
    but non are centric
    Kingston's Avatar
    Jun 2009
    Preston
    182
    The only ones i have seen at good money are these:
    http://compbrake.co.uk/shop/product_...oducts_id=3781
    20mm though but you never know they may be able to modify them.
    I have 3mm alloy spacers on the front and 6 on the back.
    random101's Avatar
    Sep 2009
    122
    did you have any issues with the centre hub i.e. would the wheel still sit flush on the centre hub im looking at 5mm to 8mm really trying to make sure the wheel sits on a centre hub lol
    Cheers!
    Kingston's Avatar
    Jun 2009
    Preston
    182
    Mine is fine sits on perfect and still sits on the spigot. I prob have 1/4 inch between Caliper and inner wheel. Looks mint. Compbrake have put some pics of it up on Facebook i'm well impressed.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    10mm or smaller don't need to be hub-centric as enough of the hub should be poking out to align the wheel on.
    I have 10mm front and 15mm rear. Works well on an S3 but you will need longer bolts. Watch out for the length though as if they are too long they will hit the hub/ABS ring and damage the thread/ABS ring and lock up your hubs...
    My 15mm spacers are eibachs but the 10mm ones I got from a guy on ebay for about 50 inc bolts and they are hubcentric. They look pretty much like the Forge ones...
    ESP Engineering I think the seller was..
    <tuffty/>
    Kingston's Avatar
    Jun 2009
    Preston
    182
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Yes good point i forgot to add i had to get some longer bolts too. Couldn't get the ones i needed so i got longer ones and got my mate to turn them down.
    random101's Avatar
    Sep 2009
    122
    yep im trying to source out some bolts as we speak
    as for the hub rings i have found a few places but non that offer 10mm hub centric with a 57.1 diameter but i will keep looking
    random101's Avatar
    Sep 2009
    122
    Cheers guys great info!!
    on ebay i can only seem to find the forge ones..
    http://cgi.ebay.com/ebaymotors/Forge...Q5fAccessories
    for 10mm
    are these like the ones you run? also you wouldnt happen to have a link for your ones?
    Edit just sent an email to esp.engineering@talktalkbusiness.net
    hopefully he can help me out
    cheers!
    Kingston's Avatar
    Jun 2009
    Preston
    182
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    I've posted a link to where I got my spacers and bolts in the 'wheel spacers' thread further down the page.
    If you've found the spacers elsewhere i'm sure they'd still sell you the correct bolts on their own!
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    I'd take it to another mechanic if he cant find the brake fluid resrviour!!
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
