EM TuningChris Nott
    mhr1972's Avatar
    Nov 2004
    37
    Inop recaro seat motor. S3 -2002
    Can i ask out there. My seat back seat motor has stopped today. Rest of electric functions work, up/down and lumber. Have checked curcuit board this seems correct by vault meter. Intend to check at motor to see if wire has failed, but seat seems complicated to pull apart. Is there a link to a diagram/plan? Has anybody else found this fault? Thanks in advance for any advice. Martin
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Limit switch maybe??
    mhr1972's Avatar
    Nov 2004
    37
    Limit switch? Is this inside the seat? Thanks
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    IIRC, there is no limit switch on the seat back adjustment. The motor may have burnt out, or more likely the wires going into the seat back have frayed and broken. See if you have continuity across the output terminals on the PCB.
    It's a bit of a mare to strip the seat down. PM me if you want the guide as it's 30MB in size.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
