Chris NottVolks Autos
Results 1 to 11 of 11
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Vagcom results after N249 bypass and reversed DV
    I ripped out all the N249 gubbins today and reversed the dv to see what effect it will have. These were my results:
    before:
    257 bhp
    271 lbft
    boost spiked at 20 psi then held at 18.5 psi
    After:
    245 bhp
    271 lbft
    boost peaked at 22 but then it gradually dropped off to 15 psi by 5500rpm!
    I'm guessing that my N249 was faulty because I used to get a fluttering noise that has now gone but maybe the reversed dv is leaking boost.
    Any thoughts?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    m444ty p's Avatar
    Oct 2009
    Clacton-On-Sea,Essex
    146
    What dv do you have?
    Westy's Avatar
    Dec 2008
    17,273
    Forge 007p with yellow spring
    S3 Build Thread
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    almost certainly the DV leaking mate, when run backwards it can creep open....
    Westy's Avatar
    Dec 2008
    17,273
    Good that's what I was hoping! I'll change the dv back later and run some more tests. Hopefully with the N249 ripped out I should hold a bit more boost than before.
    S3 Build Thread
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Post results, interested to know difference....
    Homer Simpson
    Westy's Avatar
    Dec 2008
    17,273
    Ok I'm a bit miffed! I've just done another run with my DV back to the normal position and I got almost identicle results to having a reversed DV:
    247bhp
    274lbft
    22psi from 2800rpm to 4100rpm then it starts dropping off till it reaches 15psi at 6000rpm!
    Now how was I getting 257bhp 6 months ago on a warmer day (12 degrees) with less boost with the N249 connected? Could it be that where the N249 is no longer able to open the DV I'm holding more boost and my standard tip is collapsing at 4000rpm?
    any suggestions guys?
    S3 Build Thread
    s3ollie's Avatar
    Jan 2007
    749
    Quote Originally Posted by Westle View Post
    247bhp
    274lbft
    how are you working out your BHP figure?
    8P S3
    Westy's Avatar
    Dec 2008
    17,273
    Using block 120 for bhp/torque and block 115 for boost in VCDS then I Used the spreadsheets off the Ross tech website.
    S3 Build Thread
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Nice one for testing this out Westle. I reversed my DV and it feels exactly the same as when it was the normal way around but obviously it has the loud chirp noise.
    Will be good to see if there are any differences when you get your lil problem checked out and tested again.
    Keep us posted
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    Westy's Avatar
    Dec 2008
    17,273
    Well I am running a yellow spring in my DV as opposed to the standard green one so I dont know if that makes any difference but reversed and normal produced near identicle results.
    It appears that my timing is being pulled from 4krpm onwards which ties in to my boost drop above so I'm trying to understand what could be causing it!
    S3 Build Thread
