Chris NottAH Fabrications
Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
  1. #41
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by auroan View Post
    Erm why is it a design flaw ? What is it with people lambasting the engines etc when they "uprate" other components past the supporting components designed limits.
    Meh, anything that collapses under vacuum pressure has an inherent problem in my opinion!
    We're not talking about running massive amounts of extra boost from the blower to cause TIP collapse, and extra couple of PSI has been known to cause it. All it would of taken to resolve this problem was a few metal supporting rings built into the TIP.
    I don't personally think it was designed to be as good as it could be, which in my opinion is a design flaw. Inept designers? Maybe. I think things should be designed to withstand far more than they are put through on a day to day basis.
    Anyway, you have your opinion. I have mine.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
  3. #42
    www.badger5.co.uk
    May 2004
    nr Glos
    6,951
    I personally think it was an unrelated fluke
    how?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  4. #43
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,080
    because the pipe was already split Bill. Dave putting a plug in it did effectively nothing, as he was plugging the open end of a pipe already split further up it's length.
    that's not to say that his crank case pressure hasn't been caused by a blockage elsewhere in the PCV system, as I said above.
  5. #44
    www.badger5.co.uk
    May 2004
    nr Glos
    6,951
    PCV is a t-piece, the stumpy end of which is the one way valve for manifold vac
    something got blocked else it would not build up the pressure. (some kinked pipe perhaps)
    blocking the vac pipe which goes to the manifold should not have made any difference to crankcase pressure. it would free vent into the TIP on otherwise std pipework, unless that pipework had collapsed or kinked.
    bill@badger5.co.uk
  6. #45
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,080
    thanks Bill, you've just confirmed exactly what I've been saying for this entire thread, although nobody seems to believe me.
  7. #46
    Jan 2004
    York
    1,641
    Anyway back in the real world there is something called a "cost/price ratio" You want something made to a higher spec, then you will have to pay more. Audi designs are spec'd to a given limit, going over board on the capability of components when its not needed would only either eat into profits or drive the price up.
    So fancy paying more for your S3 ?
    8V S3 Sportback with options on order
  8. #47
    www.badger5.co.uk
    May 2004
    nr Glos
    6,951
    as described its a weird one..
    stopping it breathing is the only way I can think it could presurise the crankcase, which is collapsed or kinked pipe most likely..
    bizarro
    bill@badger5.co.uk
