Volks AutosJMB Retrofits
Page 1 of 12 1234567811 ... LastLast
Results 1 to 40 of 460
Like Tree55Likes
Thread: Lets get it on then, My 2.1 conversion
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,470
    As some of you know my big end when after a oil pump failure some time ago and at the time i was trying to get it sorted with the garage i got it from but no such luck.
    Anyway the engine was stripped to find that the crank was damaged beyond repair and there were scores in the bores as well as some pitting? A second hand engine was my first choice but there a bit thin on the ice and if i did find one people were wanting a lot of money for them and had no history for the engine. The second option was try to find a good S3/TT crank? how wrong again as they are like rocking horse poo but i was offered a 1.9TDI crank and was told that they could be used as part of a stroker kit. I handed over 150 for the crank and walked away thinking what am i getting into know lol.
    What to do next? build the engine with what i had I did my research and found pete @ Integrated Engineering very helpful and i have now handed over $1600 USD to pete@IE for a stroker kit giving a 2067cc engine and 8.5:1 compression but still safe to 6500+rpms and some performance valves set with inconel exhaust valves
    The rest of the engine has been inspected and found to be good, The head will be fully stripped down cleaned and ported by my own hands as this is what i have been doing for many years. It looks like the head can be improved a lot around the exhaust ports as there is a 5-6mm difference in port size of the head and the manifold and some modification will be done to reduce carbon build up, improvement of of flow, knife edging the split ports on the inlet and will be given a light skim and so on.
    When the engine is build it will be run in and a down pipe and exhaust system will be fitted at a later date as well as a remap to make the most of the 2.1 engine, when i get the spare cash the rest of the car will be give a look over on chassis modifications and then a big turbo conversion will be considered depending on money?
    Picture will come soon of the damage engine and new parts
    But for now here is the car in question
    Car before ebay intercooler fitted
    S3 HODGE's Avatar
    Brown passenger seat.
    Apr 2009
    Dorset
    1,177
    Sounds good, Shame about the mess up with the garage. Hope all goes well.
    The One And Only Brown Bora
    Current: 2007 S3, Solar Orange - Revo Stage1 + all the toys
    Sold: 2000 S3, Black
    Sold: 2003 BAM Nogaro Blue S3, Revo Stage2, 19" Rial Daytona's, AP Coilovers
    Sold: 2001 A3 1.8T
    Sold: 2002 A3 1.8T, Custurd Code, BBS CH, AP Coilovers
    Sold: 1999 A3 1.6, Jewish Racing Gold, S4 Wheels
    Xbox live ID: o_HODGE_o
    PS3 live ID: Hodge_09
    Jun 2009
    Leeds
    3,470
    I only has the car 2 and a half months before the oil pump went and they refused to fix it ignoring all my letter and fobbing me off when ever i ring, Trading standards didn't have much luck ether so i'm fixing it and throwing in some performance modifications.
    I will take them to court for them to pay up for the standard parts put on the car, crank, big end bearing, bolts etc etc to see if i get paid out?
    But anyway let the fun begin with this engine
    BTW stay away from Blackburn Motor village trade centre
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    This should be interesting i will be keeping an eye on this thread
    Dark Vader Half sibling - MyThread
    Jun 2009
    Leeds
    3,470
    It should be good when done as it will produce loads more torque than the 1.8 so very drivable.
    Jun 2009
    Leeds
    3,470
    Ok a little update as i got the camera out today to take some pictures of some of the damage and modifications been done
    Lets start with the damage
    Main bearings
    The modifications to the head as you can see the gasket on the head, the gasket lines up with the ports on the manifold but not on the head so i did a little bit of portering to match them
    Before
    After
    Still have loads of work to do on the head as i will fit new guides and recut the seats as there is a bit of play in the valve guids
    Picked up a brand new sump today
    Painted my cam cover, boost pipe and inlet in crackle black
    All sat on my parts washer read to be fitted
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Good luck mate... I assume you aren't using the TDi crank non and just bought a stroker kit from IE?
    <tuffty/>
    Jun 2009
    Leeds
    3,470
    Still using the TDI crank
    Stroker kit as in rods and pistons for the conversion from IE
    http://www.intengineering.com/VW/18T...69691-1-2.html
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Ahhhhhhh, nice one... retains the 1.8t block... interesting... suggests no clearancing either... again, interesting...
    One to watch methinks
    <tuffty/>
    Jun 2009
    Leeds
    3,470
    The head work is going to one to watch as i have a friend with a flowbench 110 so we will do testing on that
    Jun 2009
    Leeds
    3,470
    Little update
    Finished off the exhaust ports today
    Aug 2009
    169
    Damn nice head work, plenty of material removed. How many hours to do?
    S3, 4 wheels, magical B8's, Eibach, Pipewerx equipped, glass windows, metal engine, silver paint.
    Jun 2009
    Leeds
    3,470
    I would say about 2 hours on the exhaust ports, more on the inlets.
    Aug 2009
    169
    2 hours! Im guessing this is you forte? Any pics of the inlets? Im guessing they wont be polished?
    Jun 2009
    Leeds
    3,470
    It is sort of, not started on the inlet yet.
    they wont be polished at all as thats not good for the fuel and air mix
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Andrew arnt you based in leeds?
    Aug 2009
    169
    Not good unless you want the mix to stick to the sides and dribble into the bores. Be good to see the flow on it once finished
    Jun 2009
    Leeds
    3,470
    I am based in Leeds Dan
    Kunit i know about all that stuff you could say i now it very well
    Jun 2009
    Leeds
    3,470
    Quote Originally Posted by Kunit View Post
    This is a Focus ST170 head i did for a customer i did this year
    I will be testing my head on a flow bench when done and then take measurements of the work done and repeat them again if i have to do another
    Aug 2009
    169
    Makes me want to pull the head off mine now but im definately not as good as you!
    Jun 2009
    Leeds
    3,470
    Thank you plus my prices arn't that bad either ( shameless plug lol PM me if you like about this work )
    But lets now talk about the work i can do to head and get back to my 2.1 build.
    I should get my pistons, rods and valves in the new year, the engine will be out of the car by sunday. I will order a uprated clutch on the weekend and the gasket kit so will have everything for the bottom end.
    My be looking into making a manifold for a GT30 conversion in the new year if found let me
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,373
    interesting conversion, I've never seen figures for a 'built' engine running a standard turbo....
    I assume you'll get quicker spool up and higher torque from the larger capacity? although potentially lower maximum boost capability at the upper limits of the compressor due to a larger space to stuff it into?
    Jun 2009
    Leeds
    3,470
    Not sure myself as i haven't seen any S3 running a 2.0/2.1 with K04 still?
    I will still keep the K04 until run in and when i get the cash then go GT30?
    S3 HODGE's Avatar
    Apr 2009
    Dorset
    1,177
    Looks good mate. This is one to watch.
    GT30 all the way!
    Sold: 2001 A3 1.8T
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Quote Originally Posted by Andrew@A.L.D View Post
    8P S3's do it all the time
    <tuffty/>
    Jun 2009
    Leeds
    3,470
    I can wait to see what it does after a bit of mapping
  28. #27
    Essflee's Avatar
    Mar 2008
    2,007
    Lol... Dirty boy
    revo'd
  29. #28
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Quote Originally Posted by leggy View Post
    Lol... Dirty boy
    Brilliant
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  30. #29
    RIP S3dave
    May 2004
    nr Glos
    7,177
    it should spool early, have strong torque but run out of puff earlier in the revs as the k04 compressor runs out of supply whilst the exhaust manifold and hotside chokes.
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  31. #30
    Jun 2009
    Leeds
    3,470
    Thanks badger now i'll have to save the penny's now you've said that
    Also have you hand much experience with the GT30HTA Turbo's?
  32. #31
    Jun 2009
    Leeds
    3,470
    A little update on the head
    Done some of the inlet ports and must say there not the easiest things to porter but i got it done, you can see the standard inlet and the finished one, not the best picture as its in crap lighting.
    Also cleaned up the combustion chamber
    standard inlet port
    Modified port
    Cleaned combustion chamber
    When done it will be going in for a light skim, new guides and recutting the seats
  33. #32
    RIP S3dave
    May 2004
    nr Glos
    7,177
    no personal experience, but they have a good rep for improved spool over their normal "cousins"
    GT35HTA is on my list to try one day if I need to review my existing GT35R
    www.badger5.biz
    bill@badger5.co.uk
  34. #33
    Jun 2009
    Leeds
    3,470
    little update
    Been working on the car today in the snow its been slow but its time for the engine to come out now, managed to strip most of the engine down in the bay so the only thing left on it is the crank, flywheel, clutch, pulley and thats it. Just need to borrow a crane to get it out but that will be when the snow is gone.
    As i had to dismantle part of the gear linkage on the box i notice the bush's on the brackets have seen better days to i will get in to the workshop to turn some metal bushes and hope to make it a bit more positive when shifting
  35. #34
    Jun 2009
    Leeds
    3,470
    Another small update as i'm waiting for parts from IE
    The head has been tested on a friend flow bench and has gained of 10.5% increase in flow on the inlet and 15% on the exhaust witch i thought wasn't than much but was told thats very good gains from that head. More can be had from it if i was willing to put the time into it witch i will be doing with another head but this one will be used for mine as it is.
  36. #35
    Jun 2009
    Barwell
    92
    nice work as usual mate! look forward to seeing it the car
    Audi S3 aka "Sabine" MRC remapped, 254.7bhp & 261.9lb/ft
  37. #36
    Jun 2009
    Leeds
    3,470
    Thanks mate
  38. #37
    Jun 2009
    Leeds
    3,470
    Got these today after having to pay a small charges
    JE 83mm forged pistons for 2067cc
    IE Steel rods
    Performance valve kit
    No pictures of the crank yet but i will
    Also waiting for a single mass flywheel to come so you will get pictures of that, just need to take the block to the machine shop to get it bore out as the is loads of damage to No 2 bore as at some point in its life its drop a valve or two as some major scoring.
    Brazuko likes this.
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  39. #38
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,911
    Andrew you are doing something which I think a few of us would fancy if we had the time/balls/money
    well done
  40. #39
    Jun 2009
    Leeds
    3,470
    I wouldn't of done it if it didn't spin a bearing and found out the bore had had it
    But Pete at IE did me a great deal on the parts and thought i would go for it
    Just got to get the cash together to get a GT30 or 35 Turbo on it when done
    FOR SALE
  41. #40
    Jun 2009
    Leeds
    3,470
    Got the engine block and head back from the machine shop and now has a 83mm bore and a nicely skimmed head
    Block is painted crackle black witch doesnt look that good in the pictures but it does look good in person and its very high temperature paint
    Started to get the bottom end together and ran into a few little problems, with the now 95mm stroke the pistons hit the oil jets so i tried to space the oil jet out of the way with some 2mm spacers but thats just not enough and if i go any more one of the jets will hit the trigger wheel for the CPS so the pistons will need machining witch i will get pics up when done
    The trigger wheel was also a problem as the bolt holes didn't match TDi crank ones so i modified the S3 ones to fit but i have now found out that you can use one from a 2.0 8v ABA engine that will bolt on.
    With the block back i thought i would cheap the head gasket and all is well with the ALH N/A 2.0 Passat gasket
    Spent most of the day lapping all my 20 valves in and rebuilding another head for customer but had to stop with my head as euro car parts gave me the wrong valve steam oil seals
    Now for lots of random picture
    FOR SALE
