Just a little update
Found out why the emissions were so high for the MOT, The cat was ****** due to oil form when the head gasket went and the piston ring problem. I have a new down pipe and cat coming from relentless which i will replace the cat and cut up the damaged cat pipe and make a decat pipe, i will be keeping the down pipe as i will be cutting that up for when i go big turbo so a little less fab work will be needed.
With that problem sorted i started back on the modifications, My Jamex coilovers have come and will be popping up on saturday to see s3dave for some of his tie arms, i would made some myself but i don't have the space to take them off my car to make a jig. As i'm at Daves i will pop into my local VW to order the R32 ARB's and bushes.
I have also purchased a liquid gauge and will be getting that soon, I can't wait for that as its a great bit of kit i really need.
I'm also making up a adaptor plate for the R32 throttle body i have and i've also ordered all the hoses needed to fit it
Fitted the the spacers and my god they transform the look of the car, I had my doubts with the 15mm front and 20mm rear but they seam just right and when the coilovers are fitted will look even better
