Urgent - Need Advice buying A3 TDI
karbonk
Living a little!
London
Hi all I am in a position in buying an A3 TDI 2004 65k miles and the head gasket went. He brought the parts from Audi and got a guy to fit that does privately. Has receipts of the parts brought. The head gasket and cylinder head was replace, alone with the cambelt timing belt. But not sure the waterpump was done.
If all ok, is there any issues I should worry about, about buying? Any problems after the head gasket has ben replace? Should I get AA to do a check on the car before buying?
Thanks in advance.
TO be sure get aa to check but if the receipts are there then that should be good.
Get number yourself of guy that fitted and ask him too.
If they guy fitting them new anything he would of receommended water pump when the rest was getting replaced...
Cheers.. I got the number off the guy and spoke to him, it was a mobile and he works from home. He got a quote through Audi and it was over £1300 for head gasket cylinder head, I believe it cost the guy £300.
He said that he got a receipt from the guy that carried out the work. Plus think he has the reciept for the parts brought from Audi. But I called Audi today and spoke to the guy he dealt with and he didnt have record of the parts brought. I gave him the reg of the car. Is there a way he could have brought without giving his reg?
It seems a little vague but when I go to see it im sure it will be clearer. :icon_thumright:
BEST beat is to get the AA or RAC to check it but im sure you have to give the reg when ordering parts......
Best get it checked just to b safe its only £139 from AA i think....
good luck
Cheers all for the above.
If the head gasket was changed etc and the car runs ok, are there any problems that may still occur? e.g lose power or doesn't run as well as the day it left the showroom??
..And when it shows in the maintenance book and receipts, is it a plus that its all been done or does it turn heads away when re-selling?
With the head being replaced does this show the car has been driven bad or is it just pot luck that it goes? 65k 2004.
19
44
2K
636
818
jamiekip
J
