Chris NottSky Insurance
Results 1 to 37 of 37
    Oct 2009
    178
    How thirsty is your S3 on oil ?
    i had a service almost 3 weeks ago and already i have had to top up with another litre of oil, i have no leeks etc and it doesnt seem to be burning oil from the exhaust, this cant be right ?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,160
    No that doesn't sound good! Mine uses a very small amount over a year as you'd expect but I dont cover any more than 9k miles a year.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Dec 2009
    24
    Doesnt sound to healthy.....ive had mine for a month now and hasnt lost any ......trip to a garage i think..
    Oct 2009
    178
    i have seen on other forums some audis do use a lot of oil around 1 ltr per 1000km that is around 650 miles correct ?
    i have probably coverd that milage in around 3 weeks tbh
    were else could it be going i cant work out, no leaks not burning oil, from what i can see anyway, strange.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Tbh mine does like its oil but its no way near that firsty.
    Oct 2009
    178
    well i have noted the miles and level, will keep an eye on it
    pauldazzle's Avatar
    Cardiff
    558
    Did you check the oil level when you got it back from being serviced? It's possible that they underfilled it. I'd just keep a close eye on it for a while.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    I've had to top mine up once or twice but I do alot of miles. Sounds like the garage that did the service didn't top it up enough.
    S3 Owner
    Feb 2009
    Aberdeen
    414
    Mine also likes a fair bit of oil.. No leaks either and no smoke from the exhaust.. Where would you start troubleshooting? Dont want to go looking for a problem that doesn't exist if it does just like oil??
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    It's very possible that the people who serviced it, didn't fill it up to the required level. Just keep an eye on it in the next 1,000 miles.
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    718
    In just under 3000 miles I've had to add less than a 1/4 of a ltr, my previous A4 1.8T Sport would use about 1 ltr every 2000 miles or so.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    sammi's Avatar
    verwood, Dorset
    340
    Follow sammi On Twitter
    That isnt good, have you checked in the intercooler pipework that oil isnt getting in there sounds silly but if oil is passing through the turbo seals then there will be oil residue in the intercooler pipework. you wont necessarily notice it unless you get a mate to drive behind you and check for blue smoke on boost.
    High revving engines tend to burn a little oil due to oil pressure and temp however that is a lot in that amount of time especially if its been driven sensibly.
    Our skyline is very highly strung and that uses no oil even under immense pressure like racing round the ring in 35 degree temps so I would start some self diagnosis to put your mind at easy and to sort any issues out before more lasting damage is done.
    Oct 2009
    178
    i have noticed a little oil residue in Induction Hose just before the MAF
    could this be the seals in the turbo on the way ?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Quote Originally Posted by ex_scoobydoo View Post
    No, thats the PCV system dumping oil back into the TIP.
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    Maybe they put a really low viscosity oil in, check that 1st. My main diagnosis would be he one already suggested several times that u seemed to have ignored, they underfilled it at the service and checked the level cold without starting it first and turning off and rechecking - ignore the gloommysters and check the obvious first
    Oct 2009
    178
    yer sorry i overlooked the part about underfilling, i was there when the service was done, by a friend, oil level was fine, i did use coma 5w 30 semi synthetic, as i plan on service every 6-7000 miles, i guess all i can do is keep an eye on it, maybe try better oil next time
    sammi's Avatar
    verwood, Dorset
    340
    Quote Originally Posted by MIKE GTR View Post
    You would presume that a competant garage would check this before letting a car go back to a customer but I agree that would be the best place to start and see if you loose the same oil in a similar period of time.
    Not trying to be gloomy and I really hope there isnt a problem its better to spend some time checking simple things like smoke, oil residue etc to avoid spending lots of cash with a garage or do any lasting damage, only trying to help but I am no mechanic just learnt owver the years with various high powered supercharged VW's and Turbo charged ricepods.
    hi mate i had the same problem! got my car serviced at a local garage! didn't do it properly! go to audi ask for a long life service. good luck.
    barters3's Avatar
    May 2008
    440
    Sorry to pinch this one....
    i noticed the other day that one of the pipes connecting to my dump valve has leaked slightly oilly air. (it is what i presume is the inlet to the dump valve. the oposite side to where it connects to the TIP.)
    im going to replace the clip and inspect the hose for damage.
    I was just cocerned that the air escaping was oilly, is this to be expected?
    Any advice apreciated.
    Oct 2009
    178
    Quote Originally Posted by joppydan25 View Post
    is thier a certain procedure on how to do an oil change on audi ?
    barters3's Avatar
    May 2008
    440
    i dont think there is anything different about the changing method. when i had my oil change done my mechanic let the oil drain longer than he normally would have as he was checking something else on the car. when he topped the oil back up it actually took nearlly 5 litres where as it normally takes 4.5.
    S3KO4's Avatar
    Aug 2009
    London
    850
    like all said here they didnt top up enough and my engine burns around 1liter ever 1.5k on a fast drive but I have asked many garages and it is apparently normal
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    S3 Owner
    Feb 2009
    Aberdeen
    414
    I'm using about a litre every 1.5k also.. A mate of mine who used to work at Audi said they can use a fair bit of oil but perhaps not as much as what im using. I've had a mate follow and there's no smoke, and defo no leaks.. Surely if the seals in the turbo were gone the oil level wouldn't drop that quickly would it? One would expect to find some effect from broken turbo seals? Other than oil loss that is..
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    I do an oil change every ~5k, and never need to top up more than once in that time, and not more than ~1/4 litre.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    pauldazzle's Avatar
    Cardiff
    558
    I think you need to check that the intercoolers are clear of oil. Oil could be collecting there. Wouldn't neccessarily give you a smoking exhaust as it won't be burning off.
    S3 Owner
    Feb 2009
    Aberdeen
    414
    So if there is oil in the intercoolers then the seals on the turbo are gone? Is this just a case of new seals or is it a new turbo?
  28. #27
    pauldazzle's Avatar
    Cardiff
    558
    I think a small ammount of oil in the intercooler may not be a cause for concern, but if there's a lot, that's not good at all.
    I think you can get the turbo seals replaced.
  29. #28
    May 2009
    I've put 1 litre in my S3 over the last 6000 miles.
  30. #29
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    I've not had to put any oil in my S3, and I did 9k miles or so over 2 years before I serviced it myself, using the correct VAG spec oil, Quantum Gold or something similar.
    You've got to have a laugh!
  31. #30
    barters3's Avatar
    May 2008
    440
    it is stated in my handbook that it may burn upto 1 litre per 1000 miles.
    mine uses about 1 litre every 2500 miles. just keep an eye on your levels, you will soon get to know what is normal for your car and then you can spot major drops.
  32. #31
    S3 HODGE's Avatar
    Brown passenger seat.
    Apr 2009
    Dorset
    1,177
    Im servicing mine every 5k with Quantum Gold and OEM filters. I dont have to top mine up as when 5k comes around I service her again
    The One And Only Brown Bora
    Current: 2007 S3, Solar Orange - Revo Stage1 + all the toys
    Sold: 2000 S3, Black
    Sold: 2003 BAM Nogaro Blue S3, Revo Stage2, 19" Rial Daytona's, AP Coilovers
    Sold: 2001 A3 1.8T
    Sold: 2002 A3 1.8T, Custurd Code, BBS CH, AP Coilovers
    Sold: 1999 A3 1.6, Jewish Racing Gold, S4 Wheels
    Xbox live ID: o_HODGE_o
    PS3 live ID: Hodge_09
  33. #32
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    715
    I've had the car about 2.5 years and covered about 6k miles. oil level exactly where it was 2.5 years ago. Mileage covered is either very short journeys in town and half way round m25 journeys.
    erm, that reminds me time for an oil change ! BTW, the last oil change was a long life one.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
  34. #33
    crunchie's Avatar
    Oct 2009
    Inverness
    861
    with an oil consumption like that you'll never need to service it! Lol. Service mine every 7k as its mapped, uses 250mm in this time TOPS!
  35. #34
    Oct 2009
    178
    update
    so 3 weeks later and 600 miles again another ltr of oil is needed
    as before no oil leak, car seems to be running nice, no burning smoke or oil from the exhaust, i do need i new first lamba probe but i doubt this is the cause.
    no other faults on vag com, so suggestions or ideas please guys
  36. #35
    Westy's Avatar
    Dec 2008
    17,160
    update
    If I was you mate I'd save yourself the hassel and just get it checked over by a VAG specialist. By the time you've gone through a few of our guessed suggestions you'll be another 40 down in oil costs!
    S3 Build Thread
  37. #36
    Oct 2009
    178
    yer true, a friend of a friend just said lamba probe! it will be getting to hot and burns oil, funny enough vag com said i need a new 1st lamba, the guy didnt know this, it was just the first thing he said, so maybe could be the cause, but @ 90+ will be the new year now before i buy one, but ill update once i have
  38. #37
    Westy's Avatar
    Dec 2008
    17,160
    I think you'll be best getting yourself one then mate. VCDS is normally very accurate.
    S3 Build Thread
