Badger5EM Tuning
Results 1 to 40 of 40
    55
    S3 no power and running really rich, NOT MAF!!
    Can anyone help!
    i have a 1999 s3 which has been playling up for a while. iv had all the usall problems such as split hoses ect.
    i put a forge diverter valve on it, new coil packs new n75 valve new maf also had a decat fitted a while back. but
    now its running reall ritch,( i can tell from the mpg reading also stinks!)
    also the power isnt there anymore its as if its flooding itsself because if you dive it gently its ok but
    as soon as you put your toe down more than a 3rd it just seens to die!
    at first thought it was the maf so disconnected that, still no joy. also there are no falt codes present.
    then took it to jabba sport, they looked for two hours and still no joy!!
    forgot to mention that sometimes it has a spurt of power and boosts to about 1.5 bar and really goes,
    but other times it will only boost to bout 0.7 and then really struggles.
    anyone got any suggestions???
    cheers
    p.s also jabbasport said that the maf was running about 11.5 % i no thats high but when they put a different one in it was the same.
    redrumakamurder's Avatar
    Ian Da G*
    Jun 2008
    Reading
    27
    Im not a car boffin but a few weeks ago my car was running as wat seems to be the same as wat ure is...... i took it to my good friend who's a mechanic and it turned out to be the pipe that runs from the intercooler. dont no how much else to describe it to u tbh. if u open ure bonnet its the furthers pipe forward that runs down somewhere. it has wat i call a jacket on. i no the diverter valve connects to it.
    well this had slipped half on and half off which didnt help my car at all and i had no power when i put my foot down. but then sometimes would run fine aswell. not to mention it was also making a really loud suckin noise when i put my foot down. dunno if thhis helps.
    S3 2000 Black / weitec suspension kit /Milltek Cat Back /APR remap stage 2 / neuspeed P flo / full black leathers etc etc
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    What spec are you running? 1.5bar is high for a stage 1/k04 setup
    <tuffty/>
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    CTS Would be my guess !
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Quote Originally Posted by redrumakamurder View Post
    wat wat ure u tbh.ure
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Quote Originally Posted by Byzan A4 View Post
    whats that?? catalyst temp sensor???
    Apr 2004
    12,523
    Sorry coolent Temperature Sender. Can throw silly readings at the ECU making it throw random amounts of fuel at it because the ECU thinks the engine is always cold
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    ah yeah makes sense, i have replaced mine is a very likely cause also
    Apr 2004
    12,523
    sorry i had my mind elsewhere when i typed it, but for the 20 it costs, it is a popular fail too
    55
    yhe tanks i will try that but wouldnt the coolent temp sensor put dodgey readings on the temp gauge in the dash?? also i am going to try a new lambda sensor and map sensor, just to rule them out.!!
    also my cars running compleatly standard thats why i was confused that the boost was all over the place!!
    can someone conferm the part no. of the n75 because i got a genuine one from tps but it was the reverse layout to the one i had on before ( the connector was the oppisite side) also the part no. was different cos they said my old one was discontinued.
    55
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    just standard but it will only spike upto 1.5 sometimes othertimes it ill barely reach 0.7!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Have you had the car checked for fault codes (VAGCOM or other)?
    MAP and Lambda sensors are not cheap and seems a pointless waste of cash without at least checking and logging the car first.
    <tuffty/>
    55
    yhe no fault codes also jabbasport had it for two hours and used vag com so dont no!!
    Apr 2004
    12,523
    The CTS is a 2 sensor sender, one section is for the dash, and the other feed is for the ECU
    55
    wouldnt thhat mean that i would see the same reading the ecu is seeing?
    it runs at about 70-75c on the motorway and a roads but around town it goes up to 90c but will drop again when i get going out of traffic is that normal?
    flat out if in doubt
    stoke on trent
    149
    im sure thats normal, mine does the same.im also having the same problem.loads of fuel flooding the engine
    Apr 2004
    12,523
    Quote Originally Posted by malcolm30029085 View Post
    The Sender has 2 sections, one drives the ECU one drives the dash, so you can have a fully working dash, but an open circuit on the ECU bit and vikie verkie
    stoke on trent
    149
    hi byzan, so your saying the other side of the senor could be fcuked
    55
    just an update on my power and fuling problem, seems to have full boost and power when cold ( first start up). then on my drive home from work (130 mils) after bout an hour of driving it would spike on 1.5 bar if i punched the pedal but would then loose pressure to about 0.5 bar even with my foot to the floor. but then if i built up the acceleration gradualy it wouldnt get more than 0.7 bar as if there is a leak!!! but sometimes it will run with full boost and really go and there is no tell tell air noise from a split! and also the low mpg readings and smell of petrol persist through out. !!!!
    iv checked all the pipes i can cant see anything, drove with the o2 sensor unpluged..... nothing came up . tried the base map with maf unpluged nothing. thinking maybe a misfire????
    if the lambda sensor was not working wouldnt it throw up a code?? cos i aint got none.
    55
    pretty sure its a split in a pipe, seeing as it dosnt hold the boost , its running ritch and alsothe spoil up sound is quite loud!!
    just need a part number for the n75 on an apy engine pls!!
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    You might not be running rich, the smell of petrol could be from a blocked fuel filter. Stick your head under the car infront of the rear drivers side wheel and you should see a silver cylinder held by a jubilee clip. See if the smell of petrol is coming from here.
    You may well have a knackered N75 or faulty N429 valve but I would have expected an error in Vagcom.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    55
    it shouldnt be cos i only changed it a few monthes back i check it still. do u know the correct part no for the n75 valve on a APY engine?
    Westy's Avatar
    Dec 2008
    17,283
    In which case it probably wont be the fuel filter. I dont know the part number but you friendly dealership parts dept should be able to help.
    S3 Build Thread
    55
    ok thanks do you know the best way to check the system for a leak, could i block the pipe that goes into the inlet manifold and then put pressure down the tip just after the maf? would that be correct?
    cant think of an eaisier way to see if i have a leak somewhere.
    pauldazzle's Avatar
    Cardiff
    639
    can someone conferm the part no. of the n75 because i got a genuine one from tps but it was the reverse layout to the one i had on before ( the connector was the oppisite side) also the part no. was different cos they said my old one was discontinued.[/QUOTE]
    You must of got the n75J valve which has the connector on the other side. It will work fine on your car, but will have a steeper boost spike than the standard n75C. Part no's for the n75 are all the same accept for the last letter. 058-906-283 (C, F, H, J)
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    pauldazzle's Avatar
    Cardiff
    639
    Knackered Diverter Valve? Standard DV is prone to failure.
    Max boost 0.5/0.7 bar sounds like it could be going to limp mode.
  28. #27
    55
    i have a forge one on there that i clean and re-grease reguarly. i checked it for suction before and it held well enough.
  29. #28
    pauldazzle's Avatar
    Cardiff
    639
    When it's down on boost, have you tried turning the engine off & then on again?
    If it's in limp this normally clears it.
    Common source of boost leaks are the 2 braided pipes on the inlet manifold. i.e.Fuel pressure regulator to inlet manifold, & there's another one on the plate that the n249 & n112 valves sit. The other big weak point is the large rubber pipe from the pancake pipe to the intercooler.
  30. #29
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Thats a bit of a noodle scratcher (as Flanders would say)...
    Mine doesn't do this. Says at 90 all the time, as I believe they are supposed to...
    I've also had a lambda sensor gone lately and not experienced the troubles you are having.
    Not sure if you've changed the CTS yet, but thats where I would start. Seems to be temperature related.
    Homer Simpson
  31. #30
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by pauldazzle View Post
    Bin the N249 valve as well whilst you're at it. Could be causing loss of boost....
    See here:
    N249 Bypass How To (2000 S3 - but same for many)
    Homer Simpson
  32. #31
    pauldazzle's Avatar
    Cardiff
    639
    That sounds like a stuck thermostat.
  33. #32
    55
    just a quick update changed the cts and no joy still running cold and still not much power, also had a compresson test done and thats all good!! so think i will try a thermostat next
  34. #33
    noddys3's Avatar
    Chester le Street
    101
    I know tHis is a different car but I had this problem on my focus rs and it turnedvoutvto be a split in a vacuum pipe mate! Sometimes it would fly then others I would have only 1bar of boost! Standard vacuum pipes on alot of cars are prone to split mate coz the material they r made from perish without much help!hope this helps you mate, bit of a long shot but it may enlighten you on the situation
    NW@R
    www.nedetailing.co.uk
    CaRs GoNe:
    Focus 1.6 standard engine .... huge sounds!! ( www.bassmechanix.com )
    Focus RS 383.4bhp + 378 ft/lb torque .... Weapon!!
    Now ... S3 in bits at the min, but will soon be back!!!
  35. #34
    Dec 2009
    73
    My temp gauge having trouble getting up to 90, only if car stationery. So should the gauge get to 90 and stabalise? I my car seems to run ritch while idling, if i throttle up like blip the throttle the engine hessitates then revs, are you experencing this also??
  36. #35
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    It should go to 90 and sit there, rain or shine. Anything else and there's an issue.
    Gavin
    Delivering Custom-Code to Australians. www.custom-code.co.uk
  37. #36
    55
    yhe i definatly think that as soon as i sort out the temp issue the preformance and fueling will sort it self out. gonna get a thermostat in a few days and put that on if not then gonna change all the vac pipes, then if still no joy... drive it into a wall!!!
  38. #37
    Aug 2009
    Gloucestershire
    17
    hi malcolm, did you ever get this sorted? i have the same annoying issue! thanks
  39. #38
    Aug 2009
    Gloucestershire
    17
    sorry to bother you Bryan. Where is the CTS sensor located? I have the same issue with car. thanks
  40. #39
    55
    Quote Originally Posted by g60smit View Post
    well i fitted a thermostat and that fixed the temp side of things but it is still not pulling properly, so tested the intercoolers and pipes they were fine checked all pipes they seem fine disconnected maf that didnt change anything, but have reailised that if i disconnest the batt it runs fine for a bit. dont think its going into limp mode cos if you put your foot down through the gears its ok but if your in 4 5 6 and go to boot it its dosnt go anywhere!!!!! also im spikeing at about 14psi and holding 9-10psi boost is that normal???
  41. #40
    May 2006
    Surrey
    175
    The new N75s are supposed to be opposite so I would say you have got the right one.
    Audi S3 2001. Black on Black. OE Sat Nav/Freeview. Bose. 18" Audi/BBS Splits. 10+16mm Spacers. KW Coilovers. Forge DV,tip and intercooler pipes. KnN Panel Filter. Oh and the essential Re-map. GONE
