Monster MotorsportVolks Autos
    Apr 2009
    Bromley, South East London
    117
    Advice on Vacuum Hoses
    Would any of you be able to confirm that if I was to change the vacuum hoses like in the follwoing picture example will there be fluid loss or de-pressurisation if I attempt the same.
    I have some silicone vaccum hoses lying around in various sizes that I found while having a clear out yesterday and it just got me thinking that I could use it on the s3 engine bay.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Should be fine mate, start with the vac hoses and make sure you get a good seal. Also, consider doing this (N249 Bypass How To (2000 S3 - but same for many)) at the same time.
    I'm in the process of doing mine at the moment amongst other thing, but bad weather keeps stopping me!
    Homer Simpson
    It's all in bits
    Apr 2006
    Bristol
    219
    Are this sizes in the pic correct? You state 4mm in the N249 thread Welly and this shows 3.5mm - or does it not really matter?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    It's close enough, silicone hose is reasonably flexible and will stretch over without too much problem... If not, then a kettle and hot water will aid you...
    Homer Simpson
    Apr 2009
    117
    Thanks Welly for the reply. I am ready with the TIP, top boost hoses and the newly found silicone but your right the crap weather makes it a pain in the a*** to crack on with.
    With regards to the 3.5mm your have troubles getting that in this country, only american sites stock that size. 4mm will be fine its just means that you have to use clips with 3.5mm you may not need to as it would be a very snug fit.
