Chris NottSky Insurance
Thread: Add gauges
    kachnak's Avatar
    Sala, Slovakia
    112
    Add gauges
    Hello,
    I am thinking about add some gauges to A shaft (between left door and front glass) I have driving wheel on left, but I have some questions before. I cannot find here thread what I want about instaling gauges and sensors.
    Boost tube I have already instaled, but do you know if is easy to instal sensors for OIL temperature and OIL pressure (are here some instruction to do this?) If is so hard I only put there boost gauge.
    Thank you
    Audi S3 1.8T 154kw 210hp APY 1999
    GET LOW, NO MATTER HOW!
    kachnak's Avatar
    Sala, Slovakia
    112
    in some tuning forum I read that this oil sensors can be placed to the oil tube which is going to turbo. What is your opinion?
    S3 Paul's Avatar
    Oct 2006
    2,759
    Hi there,
    The boost gauge will need an ignition live and earth for the light in the gauge,
    I think there is a blanking plug in the oil filter housing you can remove and fit an oil preasure sensor into.
    As for the oil temperature im not sure and i havent found a thread on here where this has been done,
    Noggy Blue 2001 S3
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,168
    Can plug the oil temp gauge in the same place, theres also the sump plug too, alot of people replace the sump plug with a sender.
    Covered loads on SCN paul.
