Chris NottAH Fabrications
Results 1 to 9 of 9
    flat out if in doubt
    stoke on trent
    149
    S3 will not start
    hi everyone, i hadmy car revo stage 2 on Tuesday and all was OK.came to it Wednesday and it wouldn't start.had the AA out and they said it was the cam-belt gone.luckly it was OK (silly AA bloke) but still paid for it to be done.the car doesnt want to fire, there is a spark at each plug and fuel going into the engine.fuse 10 did blow twice.had vag com on it and there is no fault.its not the immobilizer as my friend who works at Audi checked that.can anyone help?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,361
    Jase, see here Revo stage 2 yesterday and cambelt gone today
    So Ash, who changed the belt for you? Did they not think to see if the old one was ok and tackle the starting/spluttering problem first?
    Fuse 10 is the fuse for the management is it?
    stoke on trent
    149
    no he didnt check the starting problem out first as we didint no if the belt had snapped.all i no about fuse 10 is, it puts power to the fuel pump, dont no if it does any other sensors.what do you think it can be
    Apr 2004
    12,361
    When you checked for fuel, may i ask how you did this?
    Did you remove the fuel rail and see if the indavidual injetcors were spraying?
    stoke on trent
    149
    i checked from the two pipes that go to the fuel rail
    stoke on trent
    149
    1 a flow and the other a return. when i took the plugs out and turned the engine it was firing the fuel out
    Apr 2004
    12,361
    right, so fuel seems ok however the fuse blowing would indicate some kind of fault. The coil wiring is a common short, i would try the injectors plugged in to make sure they are firing. If they are it's most likely the crank sensor failing and send incorrectly timed signals for the spark/spray in my experience so far
    Assuming all was well with the physical timing. It's not turning over too fast by any chance is it? I have had a bottom pulley key shear, that put the physical timing out, but the belt looked intact still, and it still sparked and sprayed as it should
    stoke on trent
    149
    funny you say that, the wiring did look f***ed from the heat off the engine.could see the copper cores on most wires.the fuse has held while i tried turning it over
    ianysm's Avatar
    Oct 2008
    UK
    1,001
    Sounds like you found the problem then!
    Current: RenaultSport Clio 172
    Previous: 2001 ('51) S3 Quattro
    Previous: 2001 E46 M3 Coupe
    Previous: 2001 Civic Type R
