    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,470
    S3 engine removal
    Anyone take the engine out of there S3 with the gear box still in place?
    I'm stripping my engine down at the minute.
    As the block needs machining i'm taking all the pump's off, turbo is off, belts and pulleys and everything bolted to the block with the engine still in the bay.
    It looks like i will have loads of room to move it to the side to clear the flywheel and clutch.
    Has anyone done it that way?
    I'm only doing it this way is the car is in a council rented garage so i don't have that much space.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Yep can be done, refitting is more awkward, but again possible.
    I have done 2 swaps on 1.8ts so wont be much different once you get down to the nitty gritty.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    On a transverse engine I would imagine its easier to take the lot out in one hit... front panel off, drop it down a bit then out the front... imo of course
    <tuffty/>
    Apr 2004
    12,523
    er i meant an A3 mate !!
    Box can stay in place, its awkward is all. Will be worse on a quattro due to the location of the transferbox and brackets
    EDIT, I am alos assuming the front panel was removed before he started all this, as access is next to impossible otherwise.
    Jun 2009
    Leeds
    3,470
    I'll give it a go but its the only way i can do it due to the space i have in the garage
