EM TuningChris Nott
Results 1 to 8 of 8
Thread: SPARK PLUG HELP
    m444ty p's Avatar
    Oct 2009
    Clacton-On-Sea,Essex
    146
    SPARK PLUG HELP
    I thought i would change my plugs in my s3. I got a set of denso plugs from epc, part number :PK20PR-P8. Now i took my olds plugs out and they were a small thread which goes into the coil packs. The new ones are bigger at the end, amd you can not unscrew the caps. Are the denso plugs wrong? or are the plugs which are in my car wrong?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Firstly I wouldn't touch Denso with a barge pole after a set of them destroyed a mates engine...
    Try this...
    http://audi-sport.net/vb/showthread.php?t=84441
    <tuffty/>
    pauldazzle's Avatar
    Cardiff
    553
    Quote Originally Posted by tufftybloke View Post
    Try this...
    <tuffty/>
    Yep, agreed.
    NGK Platinums everytime for me
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Try this...
    <tuffty/>
    Totally agree with you here! Got denso's last year to try out, few months and the ceramic cracked causing quite a bit of missfiring
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by sandip View Post
    You were lucky mate, when my mates went, the ceramic ended up scoring the bores, wrecking the valve seats and shredding the turbine of the turbo... expensive failure...
    <tuffty/>
    S3KO4's Avatar
    Aug 2009
    London
    850
    Agree with everyone here, and NGK all the way.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    If you have taken the old one out and it is smaller and threaded then the cap is probally stuck in the coil pack. They should be the bigger ends as standard. Some come with a screw on end but I don`t like them as one unscrewed on me and knackered a coil pack
    red to red black to black blue to bits
    m444ty p's Avatar
    Oct 2009
    146
    all of the plugs have the threaded end showing.
