EM TuningVolks Autos
    44
    Misfire and random engine cut offs
    hi guys looking for some help on how to resolve this problem
    car in question is an a3 1.8t recently had a remap , engine just switches off randomly and when i start it nooo problem until it does it again
    and sometimes when i let off the accelerator and then press the accelerator theres a slight judder/misfire ,its driveable but just annoying
    your help is highly appreciated
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    It'll be either the coilpacks,plugs or ignition control module, change the plugs first, the cheaper option then look at the others
    26,776
    Ok 1st thing to ask is, did it have issues before the remap & 2nd, I advise you to get it scanned with vcds aka vagcom or buy the genuine kit, from me if needed & scan yourself
    44
    all sorted changed the ignition amplifier
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Glad you got it sorted bud
