Sky InsuranceAH Fabrications
Thread: Cambelt Change?
    imported_stuartkern
    Cambelt Change?
    Hi there all,
    Has anyone out there had a cambelt change on a A3 1.8T recently? If so, how much should I be looking at spending?
    Jun 2003
    World of my own
    9,813
    Re: Cambelt Change?
    About 250 at specialist, 400 at Audi stealer.
    As always makes sure they do the tensioner and the water pump at the same time. Water pump tends to seize which ill strip the new belt and most of your 20 valves - v. expensive for the sake of 35.
