Badger5Monster Motorsport
Results 1 to 8 of 8
    Dec 2009
    Misfire please help :( (no engine light, no codes on VAG)
    hello friends i have a noggy blue audi s3, 2000 plate, revo'd and forge dv007p (or something)....
    my car started misfiring whilst i was driving on the motorway, no engine management light, misfire only under load... when accelerating hard. anyways took it to a local garage.... said it could be spark plugs replaced with ngk platinum - drove perfect for 5 minutes and started misfiring again....
    did a bit of research, so unplugged the MAF, made no difference. took it back to the garage 3 errors on VAG-com - MAF, Secondary Air Injection Incorrect Flow (P0411), Boost Pressure Control Valve (N249): Open Circuit.... anyways garage fixed all these errors (replaced MAF) and cleared on VAG-com... drove home again started driving ok for 2minutes but under load started misfiring....
    took it back to garage, NO errors on VAG now, looked at coil packs - cylinder 3 small crack, 3rd cylinder (new) spark plug - carbon fouled (dry, soot, black), replace spark plug - worked perfect for 5 mins but started misfiring again.
    1. if the coil pack was faulty it would have shown on vag or engine management light would be on? (i have none) (yes engine management light works)
    2. spark plug keeps fouling only on cylinder 3? (my car does need a service, what else could i check for this - fuel filter, air filter, o2 sensor etc please help)
    thankyou
    S3 HODGE's Avatar
    Brown passenger seat.
    Apr 2009
    Dorset
    1,177
    Its highly likely the Coilpacks...Very common problem on the S3's.
    Maybe a good idea to bite the bullet buy all four at once as they tend to all go slowly after each other
    The One And Only Brown Bora
    Current: 2007 S3, Solar Orange - Revo Stage1 + all the toys
    Sold: 2000 S3, Black
    Sold: 2003 BAM Nogaro Blue S3, Revo Stage2, 19" Rial Daytona's, AP Coilovers
    Sold: 2001 A3 1.8T
    Sold: 2002 A3 1.8T, Custurd Code, BBS CH, AP Coilovers
    Sold: 1999 A3 1.6, Jewish Racing Gold, S4 Wheels
    Xbox live ID: o_HODGE_o
    PS3 live ID: Hodge_09
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by abc123 View Post
    Hi mate, bit concerned that they replaced the MAF based on the fault code for it. I expect the reason it came up with a fault for the MAF was because you unplugged it. This would of brought a code up saying MAF signal too low...
    Misfires don't always log in VAG COM, I had one only yesterday which didn't.
    If I was you, since the plugs have been changed, i'd get a replacement coil pack (just one) and work through the cylinders 1-4. If it's a coil, it will be one of them... Once you have identified which one it is, at least you have a working motor, then buy replacements for the other cyls as Hodge said.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    And if you're having problems with cyl 3, that would be the place to start....
    Homer Simpson
    S3 HODGE's Avatar
    Apr 2009
    Dorset
    1,177
    O yea if its fouling on cyl 3 you may find that cyl 1 will play up aswell
    Sold: 2001 A3 1.8T
    Dec 2009
    Hmmmm
    But would a faulty coil pack cause a spark plug to foul? and two different vag computers havnt picked up an error now, I though a faulty coil pack would have shown on vag
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Well, it depends what you mean by foul.... can you elaborate mate?
    Homer Simpson
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    If the coil pack is borderline, it will not throw a code. Replace coil pack 3 and try again.
    PS do not be tempted to use a pattern part, get the original from the stealer, 3 extra for peace of mind
