Chris NottJMB Retrofits
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    A3 - S3 front hub
    as above are they the same as mine is buckled and i know there is an a3 in the scrappies thanks mike
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    A buckled Hub ??? how on earth have you done that ??? are you sure it's not the wheel or the Disc ???
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    hit a curb a couple of weeks ago and thought i buckled the wheel because i was getting a shake from the front right wheel so i bought some new wheels but still get the same problem as before, so i jacked the front end up pulled the fuse out and put it in 6 gear and could see the wheel looked buckled so im now thinking its the hub, if it was the disc bent surely it wouldnt make the wheel look buckled.
