Monster MotorsportChris Nott
Results 1 to 17 of 17
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Bad misfire under boost
    I'm getting a bad misfire under boost in the S3.
    It only started yesterday on the way back from crimbo shopping, went to over take something and she had a bit of a stutter. Put it down to one of those things and carried on home. Worse today, was bad on the way to work, and has now developed into a bad misfire as soon as you get anywhere close to full boost.
    VAG COM has thrown a 16514 DTC, which is Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit - intermittent.
    This code has been there for a little while now, and i thought it strange that it would start causing problems all of a sudden...
    Any ideas good people, before I am forced to burn it?
    Homer Simpson
    s3gav's Avatar
    Jul 2009
    414
    mine did the same awhile back turned out to be coil pack though i never checked for a fault so may be something else on yours
    S3 HODGE's Avatar
    Brown passenger seat.
    Apr 2009
    Dorset
    1,177
    Most likey a Coilpack as there very well known for failing after having the remap on the S3's.... or ive heard of the MAF giving these problems?
    If it is the coilpacks it maybe a better idea to bite the bullet and get all four or you may find you will be "chasing your tail". Also buy the Genuine Coilpacks there around 30 each from TPS,GSF etc....
    Hope this helps.
    The One And Only Brown Bora
    Current: 2007 S3, Solar Orange - Revo Stage1 + all the toys
    Sold: 2000 S3, Black
    Sold: 2003 BAM Nogaro Blue S3, Revo Stage2, 19" Rial Daytona's, AP Coilovers
    Sold: 2001 A3 1.8T
    Sold: 2002 A3 1.8T, Custurd Code, BBS CH, AP Coilovers
    Sold: 1999 A3 1.6, Jewish Racing Gold, S4 Wheels
    Xbox live ID: o_HODGE_o
    PS3 live ID: Hodge_09
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    Mate you aint having no luck are you. Hope you get it sorted. Said there wasnt sumet dodgy about it though.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,603
    Does it happen on part throttle?
    Have you logged for misfires?
    Is the misfire always there during idle, part throttle and under full load?
    If the lambda is playing up then fuelling could be all over the place... could be dumping fuel under boost and giving you the misfire...
    Try logging blocks:
    001 - will tell you how much fueling the ECU is adding/taking away
    031 - will tell you AFR
    115 - requested boost v actual
    and check 032 after a run to see what the adaption values are...
    <tuffty/>
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Think it's a coil to be fair, and if it is, it's just one of those things!
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by tufftybloke View Post
    Try logging blocks:
    <tuffty/>
    No miss under idle, good as gold... I'm going to take it out in a bit and see whats what. Watch this space.
    Also, no misfires logged earlier in the engine fault codes.
    Got a copy of VAG COM 409 handy, are the measuring blocks the same?
    Homer Simpson
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    Well i hope it is mate.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Sorry to sound a little basic, you might just need a new set of plugs, when mine was missing under boost last year i ended up changing loads and in the end all it wanted was plugs
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,603
    Yeah, should all be the same... coil packs usually misfire or lumpy idle...
    Private road, third gear from 2k rpm to redline... usual story
    <tuffty/>
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    All sorted
    Took each pack out in turn and gave it a bit of love. A bit of corrosion on the electrical connector on cyl 3 I believe was the cause (must of been - wet fuel still on the spark plug), still, all good now. WD40 and a bit of 800 grade wet and dry. Did all of them for good measure. Problem gone.
    *Big Sigh*
    Homer Simpson
    S3 HODGE's Avatar
    Apr 2009
    Dorset
    1,177
    Ahh good man. Car must of been sat around for a bit before you bought it?
    Sold: 2001 A3 1.8T
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by S3 HODGE View Post
    Yes, I believe it has been for a substantial period of time. Poor old girl
    Homer Simpson
    S3 HODGE's Avatar
    Apr 2009
    Dorset
    1,177
    Just give her a good service and a nice fresh tank of fuel and she will treat you well
    Godd buy tho mate, I heard how much you payed for it!
    Sold: 2001 A3 1.8T
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Cheers dude, thats exactly what I plan to do. I only run my cars on V Power or Tesco 99 because it makes such a difference I think. Plus much cleaner burn.
    Just ordered all servicing kit for her as well - so that will be a job for just before Xmas!!
    Homer Simpson
    S3 HODGE's Avatar
    Apr 2009
    Dorset
    1,177
    Good stuff, Yea ive always run mine on V-power! Seems to burn quicker but well worth the few extra pence
    Sold: 2001 A3 1.8T
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    To be fair, when I tickle it around, I get better MPG on V Power. Problem being I never tickle it anywhere
    Homer Simpson
