Volks AutosAH Fabrications
    jayfrts's Avatar
    bouncing off the limiter!!!!
    Apr 2004
    Herts
    92
    Immobiliser/Key light
    Does anyone have trouble starting their A3??
    Sometimes when i i unlock with the key ( as mines a pikey A3!!) sometimes the immobiliser/key light flashes which stops the car starting......................
    I have to take the keys out & relock it, then go through getting in again,Then its fine.
    its not a regular occurrence, but it does get on my tits when I'm doing me getaway driving with the local badboys [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    jayfrts's Avatar
    Apr 2004
    Herts
    92
    Re: Immobiliser/Key light
    So i'm the only mug then!
    Jun 2003
    World of my own
    9,813
    The car reads some sort of code off the key, so it could be a flaky keyswitch.
    Northampton, UK
    76
    Why is it flashing when you open the car!?!?
    There is a coil around the ignition barrel that reads the key transponder. If that's knackered then unfortunately is a whole new top colum job.
    As for the other keys, the things have to be damn close for it to work. I have a VW fip key on my set as well and thus far that hasn't caused any problems.
    Cheers.
