Volks AutosJMB Retrofits
Results 1 to 20 of 20
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    Engine rebuild options, 2.1 conversion? ( Badger help? )
    Right i stripped down my engine today after finding the big ends have gone and has done some damage to the crank.
    I have found scores in the number 2 bore but the pistons are ok? looks like someone has bodged it to get it running to sell fast and i was the sucker that got it but anyway back to the problem in hand.
    Right what are my options?
    I was thinking of rebuilding the engine with a 95.5mm stroke TDI crank (2067cc) or 92.8mm 2.0 FSI crank (2008cc)? and Forged pistons and rods but whats the max the early apy engine can be bored out to?
    What else is needed for this conversion?
    What head gasket?
    Anymore infor on this conversion will help
    Olly P's Avatar
    My other cars a mk2 Golf GTi
    Dec 2008
    Oxford
    686
    Jun 2009
    Leeds
    3,472
    What car will i find the ALH block in?
    As the 2.2 conversion is looking tempting?
    Jun 2009
    Leeds
    3,472
    Just thinking what head gasket would be needed for the 2.2
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    I am sure Bill recomends an OEM Headgasket.
    Jun 2009
    Leeds
    3,472
    I'm sure it will be the ALH head gasket if using the ALH block?
    RIP S3dave
    May 2004
    nr Glos
    7,195
    i use oem but it depends on bore
    intergrated ingineering do some usefull stroker bits n bobs
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2009
    Leeds
    3,472
    Thats where i plan to get the kit from
    Not sure what to go for? I like the idea of the 2.2
    RIP S3dave
    May 2004
    nr Glos
    7,195
    oil squirter and case clearancing may be required sfaik
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2009
    Leeds
    3,472
    not a problem
    will it need a different cam belt seeing its a taller block
    Feb 2004
    2,036
    I saw a very expensive 2l conversion bottom end, yesterday, that looked suspiciously like a 2.0TFSI bottom end out of a Mk5 GTI, albeit with a machined spacer about 4mil thick between the bottom of the block and the 18T sump.
    Head dowels were tapped through, to enable head to fit, but apart from that, it all "looked" stock!
    Even the crank oil seal carrier was a stock 18T one as far as I could tell from the part number.
    Is the road to a 2 litre as simple as this...? Surely not.....!! ! !??
    Jun 2009
    Leeds
    3,472
    Why the spacer between the block and the sump?
    Jun 2009
    Leeds
    3,472
    I have some piston option now
    82.5mm bore x 95.5mm stroke = 2042cc
    83mm bore x 95.5mm stroke = 2067cc
    83.5mm bore x 95.5mm stroke = 2092cc
    What head gaskets will be needed with the above bores?
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Came across a TT bored to 2.1. Was apparently pushing out 480bhp. Certainly left me standing anyway!
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    Jun 2009
    Leeds
    3,472
    Pick up the crank on Saturday
    Jun 2009
    Leeds
    3,472
    Bump
    steve-tt's Avatar
    Feb 2007
    62
    Quote Originally Posted by ianysm View Post
    where was this?don't know of any TT of that desciption
    MRC AUDI TT 425BHP/330ftlbs1/4MILE 12.28secs
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Quote Originally Posted by Andrew@A.L.D View Post
    Sounds like a main bearing torque plate... designed to prevent teh block from twisting from loads of torques..
    http://www.034motorsport.com/product...roducts_id=680
    If you haven't alreay, check out 034 motorsports (http://www.034motorsport.com/) and Integrated Engineering (http://www.intengineering.com/) for parts for your project...
    <tuffty/>
    Jun 2009
    Leeds
    3,472
    Are the Girdle Kit! I forgot about them things
    I don't think i will be producing that much torque with what i'm doing
    Jun 2009
    1,069
    Could you not get a stroker kit, Ive seen one from america costing i think around $1500, but was a 2L kit though.
    Its gone replaced with a mk2 golf gti 16v :D
