AH FabricationsSky Insurance
Results 1 to 10 of 10
    m444ty p's Avatar
    Oct 2009
    Clacton-On-Sea,Essex
    146
    Secondary air injection system
    Is there a step by step guide to fixing this?
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,466
    Ross_S4
    Aug 2009
    Dundee
    718
    the whole system? what is not working on the system?
    m444ty p's Avatar
    Oct 2009
    146
    This is the fault code my scanner gave me.
    16795 / secondary air injection system faulty flow p0411
    Ross_S4
    Aug 2009
    Dundee
    718
    Quote Originally Posted by m444ty p View Post
    Check out this wiki from rosstech which will explain fault codes.
    http://wiki.ross-tech.com/index.php/...ry:Fault_Codes
    yours is here...
    m444ty p's Avatar
    Oct 2009
    146
    thanks i have no light on, just this code keeps coming back. What does this pump do? Will it slow my car up? cause any running problems?
    Ross_S4
    Aug 2009
    Dundee
    718
    Have a look at this post for the effects it might have.
    I believe the secondary air inlet system is to assist in emmission control when you start up from cold.
    pauldazzle's Avatar
    Cardiff
    634
    Yeah it only operates when the car is cold.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    27,072
    Its most likely goosed if no flow detected, could have become unplugged unlikely but possible or the wiring has got damaged, the rivet mod quietens it down sometimes, but on mine a pipe from the airbox had split & it had filled up with rain water over time & it was burnt out big time & yes Ross is correct it helps the cat to get working quicker.
    Sep 2009
    worcester
    1,097
    mine threw up a code for this pump, its not the same as what matty is getting, but seems similar, could someone just clarify what i should be looking at, the pump itself or its relay, if the relay where is it located please?
