EM TuningBadger5
Page 1 of 2 12 LastLast
Results 1 to 40 of 60
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Why is my engine cold to touch after a run?
    I have a AMK engine. I recently repaced my thermostat as my temperature gauge was up and down, which it fixed. However a few days before fitting the stat I noticed that the engine is only warm when the gauge and climate control says its 90 degrees.
    Before after a 20 min run I couldnt touch the strut brace, charge pipe or intake manifold but now I can keep my hand on it for however long I want.
    Any suggestion would be great thanks.
    Nathan
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Because you now drive like a granny, simples
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    lol maybe but I dont think so.
    For sale
    PM for info.
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    You have super powers and cant feel pain.
    2003 Audi S3 + Go faster bits
    27,087
    Maybe fans were on full throttle 24/7 when in use which the stat now resolved & also affected the temp readings, not unheard of.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Your hand was swapped whilst you sleep for one made of asbestos
    Seriously though, it has....check it.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    My fans are not on 24/7. They come on when the engines been idiling for a while in traffic or after I just start the car after a run.
    I been told it could be the coolant sensor but not sure how that would make my engine stay coldish.
    For sale
    PM for info.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    I wouldn't moan about it mate, most people here want lower temps under the bonnet to keep the AITs down
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Quote Originally Posted by S3 Nattie View Post
    It wouldnt, the water will still be the same temp before...the guage would be all over the place if it was the sensor?.
    Odd one. Perhaps your car just has better coolant in it now and its doing its job a bit better than before?.
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Ye I see what you mean. My car used to be boiling hot before after and a quick blast. I was constantly burning my hand on the strut brace or charge pipe if I had a quick fiddle, but know I can grip it and leave my hand on it for however long.
    It is really confusing. My gauges are working fine and my climate control is giving off respectable reading. 51C which I think is oil temperature is contantly on 75 degrees, should that be on 90.
    For sale
    PM for info.
    27,087
    The coolant sensors are synonymous on this car to be replaced, think was swapped for green one, from a black version, front coolant pipe location, but not much else can dramatically drop temps that much except the fans afaik.
    If coolant sensor/stat were fecked then fans would do all kinds of things tbh, had issues with the sensor, swapped out job done, also my fans were fecked at some point & replaced for new & stopped them running 24/7 IIRC, several reasons I guess, but cant see how yours is so low in temps now if fans are hardly running even with new coolant, I changed mine out recently, no difference but hey thats an 8P 2.0 tdi.
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Could it be a air lock in the system. It doesnt overheat or use any coolant. When I changed the stat it did lose alot of coolant so I put in the correct amount of water and anti freeze in and the coolant level has been fine ever since.
    I scanned the car the other day after changing the stat and it come up with one fault. Cant remember the code but it said something like interminet error in cooling mapped. Said thermostat or coolant sensor. I dont know if I have already fixed that problem by replacing the stat. I deleted it so will scan it again to see if it returns.
    Edit: the code was 17704 Error in mapped cooling system (usualy temp sensor or thermostat)
    For sale
    PM for info.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    An air lock can cause the issue you are having. Is there warm air coming out of the heaters?
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Ye there is warm air coming out. VAG COM is a few degrees colder than the CC though.
    What sort of intake temps should you see on a hard run according to VAG COM.
    For sale
    PM for info.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    on a remapped K04 with OEM SMIC's could be 60/70 degrees tbh....
    <tuffty/>
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Add Jimmeh on Facebook
    I had this issue with my beastie..
    I'm sure, as I said, it was the thermo/temp-switch/sender though. Will try have a dig and check it out for you.
    *edit, sorry mate - I can't find the post.
    Audi A4 Avant 1.9TDi 130 Quattro Sport.
    WhiteDetails.co.uk - Facebook? Follow me!
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    could just be the weather keeping it cool, i notice the heat soak in the summer & in winter performance is up !
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    subby's Avatar
    May 2009
    128
    thermostat ?
    1996 JDM Celica GT Four
    Sep 2009
    worcester
    1,097
    not sure if this will help you at all, but when i changed my thermo + senda, then done a flush replaced with gen audi coolant it solved my temp gauage going up and down like a yoyo, fans going crazy and engine was noticably cooler than before after long runs, before it was same as yours boiling hot under there
    now the colder weather has come along, mine struggles to get up to 90 degrees, will start to rise when stationary then dip slightly when first moving off again but soon creeps back up again, once it hits 90 it doesnt budge, ive just put this down to new senda, thermo and some 'proper job' coolant
    as some one just said, im grateful for it running a slightly lower temp, for a few miles at least lol
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Thanks for the suggestion. I done some logging earlier and after a quick blast my highest intake temp was 45 degrees.
    I no the colder weather we are having will possible help keep the engine cooler. It great to have lower intake temps as long as the ECU has adapted and is fueling correctly.
    Im sure its a problem as it was like this a week or two before I changed the stat with some mixed G12 I think it is. Thought it was down to that. Really confused what to do next.
    For sale
    PM for info.
    27,087
    Drain the system, refill slowly let it stand for an hour or 2 & then test again.
    14
    Are you driving in Siberia ?
    pauldazzle's Avatar
    Cardiff
    634
    Check the top & bottom hoses of the rad. If after a run the top hose is hot & the bottom hose is cold, you either have an air lock or a stuck thermostat.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    27,087
    Siberia, lol, yeah good point check hoses there, one idea.
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Ye that is a good suggest, will try it later. I read in another thread that there is a bleed screw on the bottom hose which comes from the rad, is that true.
    For sale
    PM for info.
    pauldazzle's Avatar
    Cardiff
    634
    Quote Originally Posted by pauldazzle View Post
    Could be a blocked rad too.
  28. #27
    Sep 2009
    worcester
    1,097
    as far as im concerned its a drain plug, not a bleed screw, but i maybe wrong, im sure someone will confirm this either way
  29. #28
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Ok, where to is the bleed screw located to on these then.
    For sale
    PM for info.
  30. #29
    Sep 2009
    worcester
    1,097
    you need to get under the car, as you look at it front on its the bottom right hand side rad hose, you should see a plastic plug thing on the bend of that hose, if i remember right just twist and pull to open
  31. #30
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    IIRC, the system is self bleeding as the expansion tank is the highest point on these cars...
    <tuffty/>
  32. #31
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Correct, no bleed screw in the system as the tanks the highest point.
    If there was a bleed screw it wouldnt be at the bottom of the rad, it'd be at the top where the airs at (or would be).
    T
  33. #32
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    That does make sense. It would likely be a drainage hole if its at the bottom.
    Bit of an update. Just when for a drive and stopped and felt the top coolant hose coming from the rad and it is hot. The bottom hose ( correct me if im wrong ) the one that goes to the thermostat was cold.
    The temp gauge and CC are both reading correctly so i take it the stat is working, but the hose going to the stat was cold. It doesn't seem to be boosting as well either.
    Any suggestions.
    For sale
    PM for info.
  34. #33
    27,087
    So you're saying you dont think the water is flowing through the rad properly, then I would empty the system & flush with hose through the system to see if it is indeed blocked or water is passing through, this would show a rad problem I would have thought, also if its a air pocket blockage then I would think this would remove this, then refill the system slowly & leave the coolant cap of standing for a few hours to allow the system to settle & the air to rise up & out as I did with my new turbo fitment recently, worked a treat.
  35. #34
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Im not to sure if the water is passing through the rad. All I can say is that the thermostat hose was cold, the fans still come on at the right times.
    Could I leave the coolant thats in there and leave the expansion cap off for a bit while the engine is idling to try and get rid of an air lock if it has one.
    Not sure if this problem is related but when I went out for a drive, I turned on the front demistor and it sounded as if all the air was coming from under my glovebox. It has never done this before.
    For sale
    PM for info.
  36. #35
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    It sounds very much to me like there is air in the system. The noise you can hear is air going through the heater matrix under the dash.
    I'd let things cool down a bit, pop to cap off the tank and let it idle for a bit. You should be able to see the coolant flowing back into the top of the expansion tank as it runs. Give the rad hoses a good old squeeze/pump to get things moving.
    Then **** it down and leave it to stand and repeat if needed till its all out.
    T
  37. #36
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    So basically take the expansion cap off. Let the engine idle and squeeze the hoses till the coolant starts to rise in the coolant tank, which should get any air locks out.
    Thanks for everyone's suggestions, this is beginning to annoy me now lol.
    For sale
    PM for info.
  38. #37
    pauldazzle's Avatar
    Cardiff
    634
    Take the expansion cap off, & let it idle for a few minutes then hold the revs at about 2500 rpm for a minute or 2 still with the cap off. Then with it at idle start squeezing the top & bottom rad hoses, which helps move any trapped air in to the expansion tank.
    Replace the cap & go for a run then let the car cool down & the check coolant level.
  39. #38
    pauldazzle's Avatar
    Cardiff
    634
    If that doesn't solve it you may well have a blocked rad.
    Be careful of using a flushing agent as I've had 2 rads split after flushing.
    I'd recommend taking the rad out & back flushing it with a hose pipe instead.
    If you're stuck try Mike & Justin at City Service Centre In Bedford St just off City Rd they are really knowledgeble, & trustworthy. Been using them for years. Tell them I recommended them & I'm sure they'll do everything they can to sort it out for you.
  40. #39
    pauldazzle's Avatar
    Cardiff
    634
    Forgot to say you should do all this with your heater on Hi & fan full on too.
  41. #40
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    i dont expect the rad to be blocked imo, are you sure you got the thermostat back back in the correct way around?? (cant remeber if its possible to get it the wroung way) seems strange that you havent removed any air leaks if you have driven the car several times and let it cool right down again, if it is an air lock you could also try going for a drive get it warm then when you get home remove the cap slowly and carefully then leave the cap off till the morning (try the other suggestions 1st though)
    are you sure the coolant is able to flow through the system have you had the water pump changed recently??
