AH FabricationsSky Insurance
Results 1 to 11 of 11
    Oct 2008
    77
    Exhaust help needed ?
    needing to replace my knackerd exhaust i have sourced a milltek downpipe and a jetex cat back stainless system
    this pic shows the downpipe on the left to jetex center. was expecting the jetex to fit over the downpipe after seeing the slits in the pipe but when fixing together the jetex fits snugly inside of the downpipe
    will this be ok to fit this way and will i need to cut some slits into the downpipe to make it close up over the center section
    cheers
    May 2006
    Surrey
    175
    Not sure if I totally understand what you have got but shouldnt there be the cats between the down pipe and cat back exhaust? If not and those two pieces do need to go together then you will need to make some slots in the outer pipe so that it will clamp down onto the inner piece.
    Audi S3 2001. Black on Black. OE Sat Nav/Freeview. Bose. 18" Audi/BBS Splits. 10+16mm Spacers. KW Coilovers. Forge DV,tip and intercooler pipes. KnN Panel Filter. Oh and the essential Re-map. GONE
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Or weld it.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Oct 2008
    77
    sorry ben
    on the left is the 3" milltek downpipe which has the sports cat and on the right is the jetex center section
    Keeno's Avatar
    Spooly Spooly Boosty Boosty!
    Apr 2009
    West Sussex
    695
    Weld it. Last a lifetime then!
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    exhaust sleeve off ebay did the trick on mine
    -AUDI A3 1.8T-
    coldside dumpvalve relocation kit/powerflow exhaust/k+n shielded air intake/ JOM coilovers/forge splitr/forge carbon fibre engine cover/soild flywheel conversion/REVO
    May 2006
    Surrey
    175
    Personally I wouldn't weld it as exhaust joints like this one are very handy for adjusting the system fitment. As suggested buy a sleeve or cut some slots in the outer pipe but make sure they are not parallel as the gasses will leak out. Where in the country are you? I may have a sleeve somewhere.
    Oct 2008
    77
    cheers guys exhaust fitted yesterday after an afternoons work
    happy with the fitment but not the noise, i thought jetex was the quiet performer
    it sounds very deep and boomy and and tends to drone could this be the 3" milltek downpipe ?
    im not adverse to loud exhausts owned a scooby with a magnex and an evo with a super dragger but this just sounds too deep
    any sugestions ?
    Oct 2008
    77
    id like to keep the miltek downpipe after seeing how restrictive the original was
    so i think options are either find a quieter catback system / backbox or to fit the old genuine system to the miltek downpipe
    any ideas
    Oct 2008
    77
    anyone ?
    Oct 2008
    77
    Would anyone advise fitting a 3" downpipe with a standard center and backbox?
