AGU head.
Dani_B19
Barnsley
Evening all.
Just want to make sure im a 100% on this, i can definately fit a AGU head onto my APY motor canti , all the valves etc can just be swapped over, no modification needs doing to allow it to fit is there?
Or just to add is a £100 for a skimmed AGU head good? Been trying to get a price to compare it with but cant find any other heads to compare it with.
If you are being supplied a head already skimmed for £100, thats good, if someone is charging you £100 to skim it, thats too much.
No thats the head already skimmed.
£50 for a large port head! Where you getting them from andrew?
I think he means £50 to have it skimmed. If you can buy a skimmed AGU head for £100, that sounds good to me :icon_thumright:
Whats the crack with an AGU head then, bigger ports?.
Mine's AGU,...does that mean I have something semi decent on my engine for a change??? :)
Normaly it means it's better except on yours. :lmfao:
It's a larger port head, TBH you will not notice a huge difference on a normally tuned engine. It's not until big power where the small port/large port issue comes in.
Small port heads tend to provide more tractability due to the air velocity, where as a large port tends to give better overall power
So it I decide to replace the hair dryer thats in my exhaust system with a proper turbo its a good thing to have?
Yes mate, it certainly is.
Tuffty has still made a reasonable increase with a small port head !!!
Pah,....I laugh in the face of his minute 'ports'....if you can call those small holes ports that is :p
Hey... i'm about to sell my old A3 AGU.... Does that mean I should swop the heads before it goes :w00t:
Yes and no, itd be aright ball ache swapping everything, you'd need to sourece a small port head and manifold to match.
Feck it.... If it's not a stright swop then i can't be bothered. I would have done it a few years ago.
728
Y
2K
