Volks AutosSky Insurance
Results 1 to 14 of 14
    Jul 2009
    520
    Possible boost leak
    I fitted my fmic yesterday, however the quality of the silicone couplings and clips is quite bad, better ones are on order.
    I have noticed on my boost gauge that the car only peaks at about 14-15 psi, where before it peaked at around 18psi, would this be the cause of a boost leak somewhere in the system? car feels a lot smoother to drive though, even though there is a lack in boost.
    Liam
    ianysm's Avatar
    Oct 2008
    UK
    1,001
    Sounds like it.
    Try going around all the connections and tightening them up then re-check the boost, or wait for your new ones to arrive
    Keen to see if the whole thing makes a difference. I'd love to fit an FMIC
    Current: RenaultSport Clio 172
    Previous: 2001 ('51) S3 Quattro
    Previous: 2001 E46 M3 Coupe
    Previous: 2001 Civic Type R
    Jul 2009
    520
    i'll probably just wait, will only be until next week and i dont really need to use the car much.
    I think mine has made a difference in the sense the car is a lot smoother to drive, plus i just love the look of them, dont know why everyone wants to hide theirs!! ha ha
    does anybody know if garages have a machine to check for boost leaks?
    Ross_S4
    Aug 2009
    Dundee
    718
    Quote Originally Posted by Plunky View Post
    Nah you don't need a machine mate!
    Just find a deserted road, lie on the bonnet slam panel with a bottle of watery washing up liquid squirted on the joints, and get a mate to boot it in third!!
    Sure you'll see the bubbles....
    Jul 2009
    520
    ha ha, thats 1 way of doing it! i'd rather get a mate to sit on the slam panel though! lol
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,063
    intersting Liam, I wouldnt have said the turbo in your car is even capable of running 18psi at all. we once ran it by mistake with an MBC where the bolt fell out, so it was running unlimited boost, and still wouldn't boost above 16psi..... and that's the most we could get it to boost with the MBC too.
    also, due to the increased volume of the fmic, and cooler air entering the inlet mani, it'll be more dense, the the hot air pumped by the turbo will occupy a smaller volume when cooled, thus reducing pressure seen in the inlet
    Jul 2009
    520
    yeah when i first got the car it peaked at about 15psi ish, i then got the downpipe/decat fitted, car seemed to boost slightly higher, then i fitted the TIP and it was peaking at around 18psi. This is only the reading from my boost gauge, so i cant be certain this is 100% accurate.
    Jul 2009
    520
    in saying this Nick, do you mean that the peak boost will be lower?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,063
    at the inlet end, yes. the N75 takes it's feed from the same place as before, but the boost gauge takes it's feed from the inlet mani, the the turbo is doing the same work, and sending the same feed to the N75, so nothing changes at that end, but the air comming out of the cooler is more dense, so occupies a smaller volume, so the pressure is a bit lower.
    The airflow going into the engine is exactly the same, it's just cooler, so better for power
    edit:| I also didn't realise you'd fitted a downpipe and TIP already, must be going pretty well now mate!
    Jul 2009
    520
    yeah its starting to come along nicely now, just got to sort a few niggily bits out then i can think about the turbo. really undecided at the minute as to weather i shouold just go with a k03s and remap, or go the whole hog and get a hybrid
    ianysm's Avatar
    Oct 2008
    UK
    1,001
    What Prawn said makes alot of sense. Does that mean the boost can now be safely increased abit, hence stage 2?
    Jul 2009
    520
    to be honest i dont know, sounds that way though.
    does anyone know, roughly what sort or % of psi i should loose due to the fmic?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,063
    dude, I wouldn't worry. most people see a few PSI drop across an FMIC, it's perfectly normal.
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    i never lost any, i gained arond 5psi untill the car re-adapted lol
