Monster MotorsportChris Nott
Thread: Air fuel ratio
    May 2009
    42
    Air fuel ratio
    Hello just a quick question does anyone know if you can use vagcom share version to check if my car is running lean. I ask because i had the car, a 1.8 t 1999 audi a3 remapped recently, its a k03s with all usual bits and a custom code phase 2. I have been having problems with low boost since its been done, i have now sorted the problem (split vac pipe) but it is hitting 20 psi on occasion and i dont want it running lean. My thoughts are that when it was mapped if the pipe was split and i have now put a new one on its getting more air. Jbs has told me not to wory and the ecu will compensate for the bit of extra air, what do u think.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    To a point they are right. As you have the early type ECU you will probably only be able to chack the Lambda voltage to see if it's in spec at .8v iirc. The older ECUs don't have accessable info for fuel trims etc iirc
    May 2009
    42
    so do you think i should just believe them and it will be ok
    Apr 2004
    12,354
    Have you vagcom?
    Thats what you need to check it, then check lambda voltage as stated, that will tell you.
    Tho TBH you won't have been sucking that much air from a simple split Vac pipe, it will probably just have been altering the way the wastegate opened/closed, or the DV worked, depending which hose it was.
    I would however make sure the FPR vac pipe is in a good state of repair. That can have a drastic effect on fueling
    m444ty p's Avatar
    Oct 2009
    Clacton-On-Sea,Essex
    146
    what is the FPR vac pipe ?
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    Fuel Pressure Regulator vac pipe connects to the fpr valve and when on boost, it lifts the fuel pressure and gives more fuel so you dont run lean
