Hello just a quick question does anyone know if you can use vagcom share version to check if my car is running lean. I ask because i had the car, a 1.8 t 1999 audi a3 remapped recently, its a k03s with all usual bits and a custom code phase 2. I have been having problems with low boost since its been done, i have now sorted the problem (split vac pipe) but it is hitting 20 psi on occasion and i dont want it running lean. My thoughts are that when it was mapped if the pipe was split and i have now put a new one on its getting more air. Jbs has told me not to wory and the ecu will compensate for the bit of extra air, what do u think.
