jdas03
Hi,
Got a problem with my brakes. I was driving down the road, been about 2 or 3 miles when i had almost total fail of the brakes.
I could push the pedal to the floor and only then would i get a little bit of braking.
The ESP light also came on and stayed lit regardless if i pressed the button again.
So i pulled over and switched the car off, it was dark so i could see much so i got back in and the brake pedal felt firm again, so i drove off again up to about 40 went to apply the brakes and same again, bake pedal to the floor followed by ESP light lighting and staying lit.
I managed to get the car home very slowly and when i looked under there was fluid coming out the bottom of the car, it was leaking from quite high up i think onto the axel.
I looked in the fluid reservoir and it was just about half full.
I just had my discs and pads changed to EBC brakes and fluid changed so this is really odd.
I have a track day on the 28th and i need this to be ready for then, any thoughts on the problem?
jdas
jdas
