JMB RetrofitsAH Fabrications
Results 1 to 9 of 9
    Sep 2009
    11
    Cylinder head help !!
    Hi all can anyone tell me if the BAM cylinder head will be ok to fit an AGU engine as agu heads are thin on the ground and expensive but been offered a reasonable BAM many thanks chris
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,468
    If both have VVT then i think it would
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    The BAM is a small port head, and i think the AGU is large port. The mounting for the tensioner is the same so they will swap over without issues. The head will physically fit, at normal tune levels it will present no problems,make sure you use the inlest and exhaust gaskest from the BAM
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    I want an AGU head but there like rockin horse ****.
    Yeah they are large port aswel.
    Apr 2004
    12,520
    Try for an AEB or AJL head they are both large port, you will just need to swap your manifolds and sensores etc on to it
    Sep 2009
    11
    are you sure ? the bam head is from the 225bhp s3 and the cupra r cant see them being small port ?
    Sep 2009
    11
    cool thanks guys ive just found out despite all the engine codes theres only 2 different heads for the 1.8t large and small port all codes adr aeb ajl apu and bam or any head with the casting number 058 103 373 are all large port the very same as the very wanted agu
    Apr 2004
    12,520
    BAM and APU are small port, so whomever told you has made an error slightly. The rest is correct.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Or yeah. Cheers mark.
