Volks AutosEM Tuning
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    S3 idle speed on startup?
    Hi.
    Can anyone confirm what their idle spped is at startup? mine sits around 11-12k rpm.. untill i start driving.. then once i return to idle it drops to 8-900.
    Is this correct? Can anyone explain why?
    Also a few times recently ive gone to put my foot down, and suddenly i lose all power, is this related to the above problem? or ESP?
    Callum
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Mine starts up at about 1000rpm - 1100rpm but goes to 800rpm once warm.
    Not sure about the power loss though - have you scanned the car for any fault codes?
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    The high cold start idle is what the car is supposed to do. It raises the revs when the secondary air pump is on to help to heat the cat faster.
    Its not a fault with the car, the ESP light will flash when it's interceeding, its like an almost complete cut in power when it cuts in
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Mine starts at about 1100 rpm when cold but soon drops to about 900-1000 or thereabouts when warm. I'd be more worried about the power loss issue, thats not right for sure.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
