EM TuningSky Insurance
    Mar 2009
    6
    Sudden loss of power
    1998 A3 1.8 Automatic
    All of a sudden the car has developed a performance drop-off problem.
    Whilst I'm rolling along normally, the car sometimes starts to judder and occasionally the engine loses power and nearly stops. I struggle along for a small distance and then it springs back to life.
    Has anyone else experienced a similar problem and what's causing it ?
    Thanks in advance.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Coil packs! Has one gone or going, you had it on vag com?
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Sounds like a coil pack issue, if you do a quick search, you will probably bring up pages of info on it, its a very common problem, however see if you can get it on Vagcom or a similar diagnostic tool, to be sure.
    Oh and they are about 30 each from main dealers, only use the original ones as the others are rubbish!!
    Mar 2009
    6
    Unfortunately it's worse than that !
    I've taken it to two Audi/VW specialists who've put the car on their diagnostic system and both have them told me that there's a fault with the ECU.
    Don't know what to do now. It's an 11 year old car - can i justify spending so much money on a new ECU and then something else goes wrong further down the line ?
    Strangely enough for the past week it hasn't played up at all.
    Maybe I need to think whether to either ;
    a) get it fixed
    b) keep driving it 'til it dies
    c) part-ex it
    d) scrappage ? (not really, I can't afford a brand new car).
