Volks AutosMonster Motorsport
Thread: Camber
    putang's Avatar
    Oct 2007
    154
    Camber
    I am currently on the look out for a set of coilovers. I got my car lowered a few months back and only just got round to getting the adjustable tie bars for the rear.
    My question is once the coilovers are on and the camber is set with the tie bars. if i lower or raise the car will this put the camber out again. meaning i will have to go back to get the suspension set up properly again.
    52 plate black s3,Star performance remap, 18" bbs lm reps, adjustable tie bars, bilstein b8s, eibach springs, forge 007p, panel filter, covered in rg55
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Put simply, yes... it will alter the camber on the rear and also alter the toe on the front.
    Depends on how much you lower or raise the car by as to what affect it will have but I would be more concerned about the front toe as it will affect the way the car drives.
    Adjust the cars height to what you want (remember not too low else the sump is at risk) then get the car re-aligned and leave it be.
    <tuffty/>
    putang's Avatar
    Oct 2007
    154
    Cheers tuffty. I thought that was the case.
