Monster MotorsportChris Nott
Results 1 to 22 of 22
    Oct 2009
    178
    Service due which oil ?
    hi
    ok my car is due a service its done just over 120000
    its had all long life services in the past but i plan to service around every 6 to 7 now i own the car, i will get a genuine oil filter, but what oil is best to use and what grade, also i plan to change the spark plugs, any sugestions on which are the best to use, should i consider anything else apart from what i have said above?
    here is a dumb question aswell
    how does the car know the service has been done, to enable the service light to go off on the dash.
    thanks.
    Ross_S4
    Aug 2009
    Dundee
    718
    you can use the buttons on the cluster to reset service counter, it is in the user manual.
    i am about to service too, using standard ngk pfr6q plugs and was planning on using castrol edge 5w-30 oil.
    did fuel filter today, couldn't believe the colour of the sh.. that came out the old one!
    Oct 2009
    178
    fuel filter thats an idea i will replace that also, i have just bought the car so im not sure tbh when that was last changed.
    grathies's Avatar
    More Points Than Portsmouth FC
    Dec 2004
    Portsmouth, Hampshire
    1,355
    I use Quantam Silver fully synthetic which I get from my local VW dealer (used to work there)
    grathies's Avatar
    Dec 2004
    1,355
    Also fuel filter isnt a usual service requirement as far as Im aware on petrols, on diesels they are as the water content can mess them up quite quickly
    Ross_S4
    Aug 2009
    Dundee
    718
    true but i don't know all of the service history of this motor before i got it...
    grathies's Avatar
    Dec 2004
    1,355
    Thats fair enough, but if youve got crap and water in your fuel system, youll know about it!
    m444ty p's Avatar
    Oct 2009
    Clacton-On-Sea,Essex
    146
    How many litres of oil do they hold?
    S3 HODGE's Avatar
    Brown passenger seat.
    Apr 2009
    Dorset
    1,177
    Buy the Quantinum stuff....I used a 5 Litre bottle on the S3 and had a little left over so im guessing you should get 5 Liters to be on the safe side.
    Hope this helps.
    The One And Only Brown Bora
    Current: 2007 S3, Solar Orange - Revo Stage1 + all the toys
    Sold: 2000 S3, Black
    Sold: 2003 BAM Nogaro Blue S3, Revo Stage2, 19" Rial Daytona's, AP Coilovers
    Sold: 2001 A3 1.8T
    Sold: 2002 A3 1.8T, Custurd Code, BBS CH, AP Coilovers
    Sold: 1999 A3 1.6, Jewish Racing Gold, S4 Wheels
    Xbox live ID: o_HODGE_o
    PS3 live ID: Hodge_09
    grathies's Avatar
    Dec 2004
    1,355
    About 4.5litres with an oil filter change as well I belive
    oilman's Avatar
    May 2008
    Sunny Cornwall / UK
    358
    You should be able to find the correct oils for your car by looking your model up here http://www.opieoils.co.uk/c-861-car-engine-oils.aspx
    Guy
    Use the code AUDIS and get 10% Club Discountoilman's website for VAG engine oil and much more - register for news and offersemail: sales@opieoils.co.ukphone: 01209 202944
    Oct 2009
    178
    would comma 5W 30 SEMI SYNTHETIC be ok for services around every 7k
    i dont see the point in buying expensive longlife fully synthetic oils when i dont plan to do longlife services.
    if someone could advise please as the service is due tomorow.
    thanks
    oilman's Avatar
    May 2008
    Sunny Cornwall / UK
    358
    That should be fine for changes at 7k, don't leave it any longer though
    Oct 2009
    178
    great stuff
    thanks for the help
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    After advice from Opie some time ago I've been using the below, it's the correct spec and just about the best oil you can get. It's not that expensive if you buy when there's a special on like there is now either:
    Motul 8100 X- lite 0W-30 Gasoline and Diesel engine oil 100% Synthetic – Ester Based
    May 2009
    42
    i use millers fully synthetic its good stuff, made my car a lot quieter
    subby's Avatar
    May 2009
    128
    Quote Originally Posted by god_thats_quick View Post
    Motul 8100 X- lite 0W-30 Gasoline and Diesel engine oil 100% Synthetic Ester Based
    Its what i use and it is supposed to be the best oil you can get. However whether the difference would be noticed to halfords special is another matter. Its nice to you you've done the most you can to prolong the life of the engine though.
    1996 JDM Celica GT Four
    oilman's Avatar
    May 2008
    Sunny Cornwall / UK
    358
    It is very good oil indeed, but you would not notice the difference between it and cheapo stuff. Well not until a few thousand miles down the line when things start going wrong if you've been using basic stuff
    S3 Paul's Avatar
    Oct 2006
    2,764
    What oil is the better option for a rebuilt up rated engine?
    I am using the quantom stuff at the moment... but not sure its the best i should use
    Noggy Blue 2001 S3
    oilman's Avatar
    May 2008
    Sunny Cornwall / UK
    358
    I would use a good 5w-40 synthetic and you will find those through the link below.
    http://www.opieoils.co.uk/c-656-5w-40.aspx
    Out of those, the best ones are the Silkolene Pro S, Motul 300V, Redline and Gulf Competition. With the mods done, it's not worth using a lesser oil. Quantum is pretty basic stuff, more about meeting specs than performance use.
    kachnak's Avatar
    Sala, Slovakia
    117
    Hello,
    What type of motor oil is recommended for audi s3 1999?
    I can not find any label in motor space.
    Thank you
    Audi S3 1.8T 154kw 210hp APY 1999
    GET LOW, NO MATTER HOW!
    oilman's Avatar
    May 2008
    Sunny Cornwall / UK
    358
    Originally a VW503.01 spec oil such as these http://www.opieoils.co.uk/c-748-vw-50301-oil.aspx
    Guy
